Go to Post One button, ten copyrights, you do the math. - StephLee [more]
Unread 01-04-2012, 12:47
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Re: pic: Triple Balance 2 of 3: CT Regional
Originally Posted by AcesJames View Post
2168 (as far as I know) in their starting configuration is short enough to be able to drop their stinger on the opposite side of the field and still not reach the full 60". I believe that the 228 machine is a fair bit taller.
2168 looks like they may exceed 60" total height in this picture. In the linked image of 67/469 above it appears that 469 would definitely be taller than 60" if their stinger was deployed.
If you have a stinger that makes the entire vertical height of your robot greater than 60", can you deploy it on the lane-side of your bridge without incurring a foul? Manual seems to say no.
Originally Posted by G20
Robots in contact with the carpet and/or Key on their Alliance Station end of the Court are limited to 60 in tall. Otherwise, Robots are limited to 84 in tall.
Violation: Foul; or Technical-Foul for repeated or continuous violation.
