Go to Post Hmmm, the Michelangelo method of robot building. Just cut away anything that doesn't look like a robot. - GaryVoshol [more]
Unread 01-04-2012, 19:34
MarcD79's Avatar
MarcD79 MarcD79 is offline
AKA: Marc
FRC #0176 (Aces High 176)
MarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond repute
Re: pic: Triple Balance 2 of 3: CT Regional
Originally Posted by bam-bam View Post
I'm pretty sure they do now.
If you check below 118, you can see part of its bridge mechanism blocked by a head.
And something tells me that this is the first time there was two stingers in a triple balance.
Be careful of the Stingers. If you enter the ramp from the opposing side, you can't exceed the 5' rule, you are in violation. The 5' rule will be measured from the top of your robot to the lowest part of your robot...the bottom of the stinger. There was a 3 point penalty in CT on Saturday, but wasn't the 1st one to be a penalty at a regional. You CAN exceed the 5' rule on your own side of the field.
Mentor & Volunteer
Field setup, Field Supervisor & disassemble Suffield Shakedown 2003- present (2015)
Connecticut Regional Field setup, disassemble & FTAA 2009, 2010, 2011, 2012, 2013 (Field reset & Assistant Field Supervisor), Field Reset Pine Tree Regional 2013, Field Supervisor, setup & take-down at Groton & Southington Districts 2014, Field Reset Hartford District 2014. Field Reset Boston District Championship 2014. FLL Judge Fall 2014
Field Supervisor/Set-up & Take-down Waterbury & Springfield , Field Reset/Set-up & take-down Hartford N/E District 2015. Field Reset NE Champs 2015. FLL Judge Fall 2015.
Suffield Shakedown 2016, Field Super 2016 Stronghold Waterbury.
