Go to Post "The reason we struggle with insecurity is because we compare our behind-the-scenes with everyone else's highlight reel." - davidthefat [more]
Unread 01-04-2012, 19:51
davepowers's Avatar
davepowers davepowers is offline
Currently dreaming about robots
AKA: Danger Dave
FRC #1687 (Highlander Robotics)
davepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud of
Re: pic: Triple Balance 2 of 3: CT Regional
Originally Posted by dsmoker View Post
Dave is right, there was no disqualification, but I believe the refs said a second violation would result in a yellow card and a third a DQ, so that in future matches it would not just a 3-point penalty, as someone earlier in this thread stated.
This is true, we were told it would be a yellow card the next time, and a DQ the time after that, which I was a little confused with because the manual states it would only be a Technical for repeated use.
Originally Posted by 2012 FRC Game Manual
[G20]
Robots in contact with the carpet and/or Key on their Alliance Station end of the Court are limited to 60 in tall. Otherwise, Robots are limited to 84 in tall.
Violation: Foul; or Technical-Foul for repeated or continuous violation.
-D
David Powers - Deans List Finalist - WPI 17' - Bleed True Clothing
1999-xxxx FRC228, GUS Robotics Inc.
2013-xxxx FRC1678, Highlander Robotics
