Go to Post In the end, people can throw all the stories at me they want, but I'm never going to let mere stories convince me physics is wrong. - AdamHeard [more]
Unread 01-04-2012, 21:37
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
slijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to behold
Re: pic: Triple Balance 2 of 3: CT Regional
Originally Posted by cj3958 View Post
Now wouldn't that also make it illegal to go over the bumb if you were exactly 60" tall? If you think about it you could be potentiallt 64" tall and be on the opposite side of the feild, no? Also the intention of the 60" while on d-fence was that you weren't blocking shots, so if you dont block any shots because of your stinger then they should just not call the penalty.
The Q&A makes this answer very clear:
Q. Please define "tall" verses "height" specified in ROBOT R02. Is "height" an absolute measurement from the carpeted floor of the arena whereas "tall" references the robot's height when only on the carpeted surface? Example: A 60" tall robot balanced on top of a 12" bridge is 72" in height. FRC1985 2012-01-12
A. The vertical measurement is always in relation to the Robot.
Regardless of the "spirit" of the rule, a rule means what it says. Until the GDC says otherwise, the 60" restriction stays.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
