Go to Post According to my father the hint should be released sometime next week, but he's never been the most trustworthy source of info.... - Lil' Lavery [more]
Unread 04-04-2012, 14:22
JABot67 JABot67 is offline
Unregistered User
AKA: John Bottenberg
FRC #2930 (Sonic Squirrels)
JABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond repute
Re: pic: Two bot side balance
Originally Posted by Nathan Streeter View Post
Agreed... This is fundamentally the exact same mechanism of "grasping" the sidewall as 118 used if the CG isn't over the bridge surface, like you said. The only solutions physics could allow for this Free Body Diagram (that I can think of) would involve either "gluing" yourself to the surface of the bridge or "grasping" the sidewall of the bridge similar to how 118 did.
I don't have that hard a time believing this one wasn't ruled illegal, though... This one looks to basically be sitting on the bridge. 118 looked to be hanging off the side. So much of how the GDC ends up ruling things is based off how the solution looks. If they see something they don't like, it seems like they then figure out how to rule it illegal... * sigh *
I watched this team's alliance triple balance on the practice field. If there is any more weight on the side off the bridge, the robot will fall off. It does not "grasp" the bridge. It does not apply force to two or more sides of an arena element. The notch is there for alignment.
John Bottenberg - University of Michigan '14 - Microsoft
FLL Team "Dark Matter": 2003-2005
Robofest Team "Dark Matter": 2005-2008
Team 67 Programmer: 2007-2010
Team 3322 Programming Mentor: 2012-2014
Team 2930 Engineering Mentor: 2015-????
Unread 04-04-2012, 14:23
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
People need to relax a bit before coming to conclusions on this and ask questions.
Hey cptopher, can you explain how this works because it's legality might be questionable? If it is legal though that is some clever work and I commend you for pulling this off.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
lnader's Avatar
lnader lnader is offline
Jedi Master of Robot Articulation
AKA: The Mentor with the Moustache
FRC #3098 (The Captains)
lnader is an unknown quantity at this point
I was able to see this robot in action. It is steel ballast on the edge. The parts you see under the robot are alignment guides, and do not touch the sides the the rail when it is on the bridge. I believe (not being certain) that there is a surface which rides on top of the rail.
It would be no different than if a robot got bumped off the side of the bridge and they were resting on their chassis.
The head referee checked at the end of each match to make sure there was no lateral contact on the bridge.
1999 - 2002: Pit Crew/Drive Team FRC 67
2005 - 2006: Mentor/Drive Coach FRC 1596
2007 - 2008: Scorekeeper/Referee
2010 - Present: Mentor FRC 3098, Robot Inspector, Referee
Unread 04-04-2012, 14:28
cptopher cptopher is offline
AKA: Chris Purdy
FRC #3534 (House of Cards)
cptopher has much to be proud ofcptopher has much to be proud ofcptopher has much to be proud ofcptopher has much to be proud ofcptopher has much to be proud ofcptopher has much to be proud ofcptopher has much to be proud ofcptopher has much to be proud ofcptopher has much to be proud ofcptopher has much to be proud of
It is just a a simple CG trick. 98 lbs on the right side wheels, 20 on the left. We sit on the rail, with a simple guide that its twice the width of the flange for alignment only. The belt drive gives us traction on the top surface only.
This was a huge design commitment for the team. All 4 Cims and gearboxes are on the right side with a driveshaft to the left wheels. The belt is driven by this shaft, geared for the same linear speed as the wheels. We have 30lbs of balast weight on the right side C rail. And a sliding battery tray. The super low CG also makes us a good stable two bot regular balancer too.
Thanks to all for the interest. We were honored to receive the Creativity Award at Livonia districts.
Chris
Team 3534 ME Mentor
Wow, cool! It's hard to tell from the photo that there is ballast on the bridge side of the robot, thanks for clearing that up.
Are you going to champs?
Unread 04-04-2012, 14:29
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Chris
Team 3534 ME Mentor
Cool.
Do you have any pictures showing the drive train from below? I'd like to see the belt and drive shaft more closely.
--Madison--
...down at the Ozdust!
Unread 04-04-2012, 14:30
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
Genius! Again, congratulations! You guys clearly put a tremendous amount of work into this - I hope it succeeds!
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 04-04-2012, 14:33
jblay's Avatar
AKA: Joe Blay
Chris
Team 3534 ME Mentor
That is an incredible design comitment. This is one of the most creative things I have ever seen in my time in FIRST. Will you guys be at championships? I would love to take a closer look at this robot.
Unread 04-04-2012, 14:37
Peck's Avatar
Peck Peck is offline
worse then failing: proving murphy
FRC #1619 (Up-A-Creek Robotics) and FTC # 4633)
Peck will become famous soon enough
man, that is cool. great job
Cad, Electrical, Machining, Debugging (old school), PR, Distraction elimination
TEAM 1619
__UP-A-Creek Robotics__
It ain't done till it's over-done
Unread 04-04-2012, 14:40
Brandon Holley's Avatar
Wow, kudos on a very unique design! That is quite a commitment. I always enjoy seeing outside the box, yet legal, designs.
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 04-04-2012, 14:55
RobotMom's Avatar
RobotMom RobotMom is offline
FRC & FLL mentor
FRC #2557 (SOTAbots)
RobotMom is a name known to allRobotMom is a name known to allRobotMom is a name known to allRobotMom is a name known to allRobotMom is a name known to allRobotMom is a name known to all
I love seeing what other teams come up with each year. Very creative!
Was your team able to do a triple balance like this during competition?
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Here's a description of another team that does something similar: http://www.chiefdelphi.com/forums/sh...9&postcount=11
Unread 04-04-2012, 16:58
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
I'm glad that this worked for you; it is really cool. In 2010, My team, 1350, built a robot that functioned identically when completely inverted (it didn't have a top, just two bottoms joined at their bumper zones). It worked, but not particularly well, especially after the frame started to bend.
Unread 04-04-2012, 16:59
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
WOW! Very well done! Building your entire robot with this design constraint is a remarkable accomplishment!
Very deserving of the creativity award!
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
Unread 04-04-2012, 17:08
AKA: Chris Purdy
Unfortunately we are on the bubble to get into the state championship. We probably won't get in. We performed poorly at Kettering but had a great weekend at Livonia. Our first time in eliminations and going to semi finals far surpassed our goal this season.
We are disappointed because we really wanted to pull off a 3 long bot balance in competition at Livonia. When we fell off the bridge once, it broke a belt pulley side which eventually broke our lower chain.
The bot will balance without the side guides. It rests on the belt vertically only. Its all very simple weight and balance calculations. The side guides just help to keep us on the center of the belt and lined up. They are fixed and do not move. They don't grab the sides of the rail to stabilize.
The inspiration came from a rail grind sliding move in skateboarding, or riding the pipe in snowboarding. Just needed the belt for more traction. I'll post some photos soon.
Thanks to everyone for the positive comments.
