Go to Post I need a This-Is-What-I-Meant checker. - N7UJJ [more]
Unread 16-04-2012, 23:03
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: paper: Shooter Wheel Speed Control
Originally Posted by ~Cory~ View Post
We started to look into this. After about an hour we came up with a few tests. We have an average of +- 18.2 rpm change from the target rpm.
Raw data is in this white paper:
http://www.chiefdelphi.com/media/papers/2667
Thank you for posting the data.
Would you mind posting the following additional information please?
- what motor(s)
- total gear ratio from motor to wheel(s).
- what type and diameter wheel(s)?
- Jag or Vic?
- coast or brake mode?
- voltage ramp rate? symmetric or up only?
- what encoder model, and where mounted
- what language
- 1x 2x or 4x decoding?
- Counter or Encoder class?
- to measure RPM, are you measuring the time between consecutive counts, or are you dividing the counts by the delta time?
- if dividing counts by delta time (see above item), how are you computing the delta time
- encoder signal not filtered?
- what execution cycle update rate?
PS: You have some interesting noise on your sensor signal. Look at cells B57 & B58 for example.
