Go to Post you know you're going to meet someone important, so you put on your robotics team shirt. - NorviewsVeteran [more]
Unread 16-04-2012, 17:11
pic: FRC973 Testing Bridge Stability
Unread 16-04-2012, 17:12
Re: pic: FRC973 Testing Bridge Stability
Where's the top part? I only ask in the name of science.
Unread 16-04-2012, 17:13
steelerborn's Avatar
steelerborn steelerborn is offline
Engineer at JBT FoodTech
AKA: Jonathan Stokes
FRC #5817 (Uni-Rex)
steelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant future
I don't think the shooter mechanism is on, 973 seemed a lot taller at CVR.
Good enough is the enemy of anything great!
team 1671
Unread 16-04-2012, 17:16
It's on there, it's just not powdercoated.
Unread 16-04-2012, 17:27
Nate Laverdure's Avatar
FRC #2363
Adding bumpers probably also made a non-negligible change in your CG position.
Unread 16-04-2012, 17:31
It would lower our CG though.
Unread 16-04-2012, 17:34
FRC #2363
Right, just saying. It might even offset the contribution caused by "the top part" (which you just said was on there, but doesn't quite match the other picture).
Unread 16-04-2012, 19:04
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
What kind of tread do you have on your wheels?
694th post
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 16-04-2012, 20:45
rcmolloy's Avatar
rcmolloy rcmolloy is offline
AKA: Robert Cory Molloy
rcmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond repute
694th post
Wedgetop tread. Not sure the actual source. Adam can back that up though.
FRC 1647: Iron Devils - 2009 - 2011
FRC 973: Greybots - 2011 - 20XX
"While I was a student in FIRST, it was all about becoming inspired. Now as a mentor/engineering student, it's all about making sure learn everything I can so I can carry that on inspiration for future generations while having a hell of a lot of fun!"
Unread 16-04-2012, 20:49
Andrew Lawrence
694th post
Looks like Wedgetop tread from Andymark
Unread 16-04-2012, 21:16
jblay's Avatar
AKA: Joe Blay
Originally Posted by SuperNerd256 View Post
That's what I figured it was but I just don't understand how that is possible without tread that deploys epoxy between itself and the bridge.
Unread 16-04-2012, 21:24
Andrew Lawrence
From what I hear, wedgetop tread has more traction on surfaces like hdpe than roughtop or blue nitrile tread. That's the main reason most top teams used it.
Also, I'm not sure if the robot has an active breaking system on it or not. That could help. 256 had software breaks that worked so well we could be at a 45 degree angle and still stay where we were without falling. Of course, these disabled when the robot was turned off.
Unread 16-04-2012, 21:44
FRC #1836 (MilkenKnights)
also, with swerve you can turn your wheels parallel to the axis of rotation of the bridge, so that your wheels don't turn at all.
Unread 16-04-2012, 23:11
Yup.
It's also AndyMark supplied wedgetop.
the robot is missing the bridge mech in this pic, but that's only ~3 lbs and doesn't apreciably affect CG. The shooter as it exists on comp bot is on this in all it's heaviness.
Unread 16-04-2012, 23:33
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Cool, swerve! Does anyone know if there are higher resolution pictures of the modules on CD?
-Plutarch
