Go to Post If you're sore over the vigorous defense teams play, get over it. It happens and will continue to, as the majority of people hope. - AmyPrib [more]
Unread 17-04-2012, 15:01
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: paper: Shooter Wheel Speed Control
Originally Posted by nighterfighter View Post
As for the CAN vs FPGA, we aren't sure. We used 2CAN, as we read that it its much faster than the serial form of CAN.
Just to be clear: CAN is a serial protocol. 2CAN also uses serial protocols (Ethernet on the cRIO side and CAN on the other).
What you meant is that Ethernet (2CAN) is faster than the RS232 connection from the cRIO to the Jag. No argument there.
But I'd bet a hundred bucks that reading the FPGA is faster than querying the Jag for speed.
One thing we did try was having the second motor in brake mode ... but it got too hot for our liking.
That's one reason why the paper says don't use brake mode.
