Go to Post Ok, so you are going to use a robot to hold all of those rivets together? - gblake [more]
Unread 17-04-2012, 22:28
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: paper: Shooter Wheel Speed Control
Originally Posted by Tom Line View Post
Is there any specific reason to use a counter class rather than encoder class?
For the shooter wheel application, you don't need the extra channel for direction. Less wiring, frees up a channel on the DS.
Just curious: did you try using the encoder as described on pages 1 & 2 in revA of the paper?
