Go to Post Off-season events aren't just for gameplay, they should also be a training session for new students and rookie teams. - Bill Moore [more]
Unread 19-04-2012, 13:54
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: paper: Shooter Wheel Speed Control
Try this: get rid of the speed filter*, get rid of the time-based slew around the control point, and put all three of these operations in the 10ms Timed Structure, in this order, with no other code:
1) read encoder counts from FPGA
2) compute (unfiltered) speed
3) send either 0.0 or 1.0 to motor controller** depending on whether unfiltered speed is above or below the setpoint
* you can filter the speed for purposes of display or logging or control of other logic (such as when to shoot), but don't use the filtered speed for the bang-bang logic
** get rid of all possible overhead in the library, like "motor safe" etc.
Reading the encoder with the getrate from the labview getrate ntroduces a large amount of noise that counteracts any positive effect from the bang-bang (for us). What you suggest is how we started out, and there's a huge amount of error (+/-100rpm).
We'll play around a bit more at 10ms using our own rate calculation and not the FPGA. Perhaps that will improve our results.
