Go to Post A better way would be better..... - WizardOfAz [more]
Unread 19-04-2012, 13:58
~Cory~'s Avatar
~Cory~ ~Cory~ is offline
Student
AKA: Cory Rypkema
FRC #0706
~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold
Re: paper: Shooter Wheel Speed Control
Originally Posted by Tom Line View Post
Is there any specific reason to use a counter class rather than encoder class?
We used a gear tooth rather than an encoder.
Originally Posted by Ether
Thank you for posting the data.
Would you mind posting the following additional information please?
- what motor(s)
- total gear ratio from motor to wheel(s).
- what type and diameter wheel(s)?
- Jag or Vic?
- coast or brake mode?
- voltage ramp rate? symmetric or up only?
- what encoder model, and where mounted
- what language
- 1x 2x or 4x decoding?
- Counter or Encoder class?
- to measure RPM, are you measuring the time between consecutive counts, or are you dividing the counts by the delta time?
- if dividing counts by delta time (see above item), how are you computing the delta time
- encoder signal not filtered?
- what execution cycle update rate?
PS: You have some interesting noise on your sensor signal. Look at cells B57 & B58 for example.
We will be working on this again tonight and I will repost updated information over the weekend
corin.rypkema.org
WPI Class of '17
'12 Dean's List Finalist, Mentor of 706 - Cyberhawks
