Go to Post As Shakespeare once said in Julius Caeser, "Cowards die many times before their deaths; the valiant never taste of death but once." - artdutra04 [more]
  #31   Spotlight this post!
Unread 19-04-2012, 18:18
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: paper: Shooter Wheel Speed Control
Tom Line:
We'll play around a bit more at 10ms using our own rate calculation and not the FPGA.
Ether:
I was assuming that your rate calculation involved getting the encoder counts and dividing by the elapsed time, is that right? If so, when you call a library function to get the encoder counts, you are getting them from the FPGA.
Reading the encoder with the getrate from the labview getrate ntroduces a large amount of noise that counteracts any positive effect from the bang-bang (for us).
I think that may be due to lag and filtering. I think it would be worthwhile to test that in the context of my previous post.
What you suggest is how we started out, and there's a huge amount of error (+/-100rpm).
Please clarify what this +/-100RPM number means (see Chris' post)
