Re: pic: A small, magenta 3D Printed Scale Model of 4183's robot, TiMMy
Originally Posted by DampRobot
Cool! I've been trying to get a similar model made on my team's Thing-O-Matic. Did you use the shrinkwrap tool in Inventor or make a new to scale model? If you did use shrinkwrap, what settings did you use?
We drew an entirely new model in Inventor. It's all very approximate, and the proportions of the robot are scaled to make it buildable.
The Ultimaker works pretty well. I'm still getting it dialed in. There is a problem with leaking plastic dripping on the product, which has caused print shifting problems. (The extruder barrel to nozzle seal is critical and it's not documented in the build wiki. )
--David Forbes
Mentor, Bit Buckets team 4183. Assistant cat herder and dispenser of legendary tales.
Need a Nixie watch? Yes, you do. Ask me.
