Thread Tools |
Rating:
Display Modes |
Re: paper: Team 341 Vision System Code
Thanks for the code. I believe lines 322-334:
Code:
private double boundAngle0to360Degrees(double angle)
// Naive algorithm
while(angle >= 360.0)
angle -= 360.0;
while(angle < 0.0)
angle += 360.0;
return angle;
Code:
return(abs(angle)%360.0);
Code:
double ret = abs(angle)%360.0;
if(angle < 0.0)
ret = -ret;
return(ret);
right.
done. This one kind of defeats the purpose of making your code simpler, though.
Code:
public static double boundAngle0to360Degrees(double angle)
return(angle > 0.0? angle % 360.0 : 360.0*(1 + (Math.abs((int)angle)/360))+angle);
Code:
return((angle+360)%360);
It's awesome that you guys are analyzing the code and you have already taught me something new (that Java's "%" operator works on floating point values...as a primarily C++ guy, I have it burned into my brain that thou shalt use "fmod" for floating point modulus). But if this is the part of the code that engenders the most discussion, then I'm a bit disappointed ![]() Last edited by Jared Russell : 07-05-2012 at 08:13. |
Code:
return(((angle%360)+360)%360); |
I feel like at this point the original code was easier to understand from an outside perspective.
On another note, this is AWESOME! It's nice to see another team using Java to program, especially when it's done so well. Our camera tracking system is currently only used in auton to track after grabbing the third ball off the co-op bridge. It's very rudimentary code so that it can be run on the cRio (we had issues with a bad camera that made it impossible to test any sort of laptop based vision code). This is very interesting, and I'm excited to go over it in more detail later. |
Thanks for posting this, Jared. I took a look at your dashboard on the field at Champs and was very impressed. It seems incredibly useful to have the vision system draw its idea of target state on top of the real image.
I suspect if vision is a part of upcoming games, we will probably use a solution very similar to this. This year we wrote all of our vision code on top of WPILib/NIVision to run on the cRIO. In the end we got this to work pretty well, but development and debugging was a bit of a pain compared to your system. |
#10
Very cool! I just finished taking an online data structures course from IIT, so it was really awesome to see the implementation of the TreeMap! Just so that I'm sure I understand, it is used to quickly find an rpm based on your distance, right? What are the advantages (if any) of using this instead of plugging your data points into an excel graph and getting a polynomial best fit equation to transform your distance into an rpm?
#11
#12
While I'm here though... if you are a c++ guy why use Java? Is it because it was the only way to interface with the dashboard? I gave up when trying to figure out how to do that in wind river. |
#14
Easy, it's because I am not the only person who writes software for our team! Java is what is taught to our AP CS students, and is a lot friendlier to our students (in that it is a lot harder to accidentally shoot yourself in the foot). I also have a lot of training in Java (and still use it on a nearly daily basis), even if C++ is my bread and butter.
#15
I will reveal one piece now with this video: http://www.termstech.com/files/RR_LockingDemo2.mp4 When I first saw the original video, it screamed high saturation levels of red and blue on the alliance colors, and this turns out to be true. The advantage is that there is a larger line to track at a higher point as I could use particle detection alone. The goal then was to interpret the line to perspective and use that to determine my location on the field. From the location I had everything I needed as I then go to an array table error correction grid with linear interpolation from one point to the next. (The grid among other tweaks are written in LUA more on that later too). more to come... There is one question that I would like to throw out there now though... Does anyone at all work with UYVY color space (a.k.a YPbPr). We work with this natively at NewTek, and it would be nice to see who else does. |
