Go to Post A game where you don't have control of your robot for long periods of time is no fun (unless, of course you are talking about autonomous :p) - Cody Carey [more]
Unread 07-05-2012, 12:55
ttldomination's Avatar
Sunny
Re: pic: Prototype 8 Wheel Drive Chasis
Originally Posted by tzjin View Post
Why not have the gearboxes in the center? An 8WD needs to have a center of gravity somewhere over the two middle wheels, or it will rock violently while turning. Chain will also be nicer if its symmetric on both sides.
I think if you maintain your COB on any portion of the DT, it'll really be ok. Sometimes, it's preferred that the gearbox is in the front/back to leave for a large mechanism/intake. Either way, I can say that on a 6WD it wasn't that bad, and I doubt it'll be as bad on a 8WD.
Originally Posted by Yalib View Post
If you bring the two middle wheels on each side closer to each other you would probably get better turning ability.. looks good!
good luck!
Bringing the two middle wheels closer will allow for better turning, however, I think it will also cause relatively more rocking/disturbance. I suppose this is why we've seen various teams opt for the 8WD, but the middle wheels are actually spaced out *more* for added stability.
- Sunny G.
1648: 2013-2014
5283: 2015
