Go to Post Temp wiring is always bad but it is made worse when dealing with a $1000 part. You wouldn't try to lash a makeshift power source to your PC. - Al Skierkiewicz [more]
Thread Tools Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
Unread 08-05-2012, 00:11
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
Re: paper: Team 341 Vision System Code
Originally Posted by Jared341 View Post
What if angle is equal to -361?
It's awesome that you guys are analyzing the code and you have already taught me something new (that Java's "%" operator works on floating point values...as a primarily C++ guy, I have it burned into my brain that thou shalt use "fmod" for floating point modulus). But if this is the part of the code that engenders the most discussion, then I'm a bit disappointed
Ok, fine.
Code:
return(((angle%360)+360)%360);
Unread 08-05-2012, 19:58
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
I feel like at this point the original code was easier to understand from an outside perspective.
On another note, this is AWESOME! It's nice to see another team using Java to program, especially when it's done so well. Our camera tracking system is currently only used in auton to track after grabbing the third ball off the co-op bridge. It's very rudimentary code so that it can be run on the cRio (we had issues with a bad camera that made it impossible to test any sort of laptop based vision code). This is very interesting, and I'm excited to go over it in more detail later.
www.sharkattack744.com
Unread 08-05-2012, 20:58
Custom User Title
Send a message via AIM to Tom Bottiglieri
Thanks for posting this, Jared. I took a look at your dashboard on the field at Champs and was very impressed. It seems incredibly useful to have the vision system draw its idea of target state on top of the real image.
I suspect if vision is a part of upcoming games, we will probably use a solution very similar to this. This year we wrote all of our vision code on top of WPILib/NIVision to run on the cRIO. In the end we got this to work pretty well, but development and debugging was a bit of a pain compared to your system.
Unread 09-05-2012, 09:43
Leeebowitz Leeebowitz is offline
AKA: David
FRC #2115 (Nightmares)
Leeebowitz is an unknown quantity at this point
Very cool! I just finished taking an online data structures course from IIT, so it was really awesome to see the implementation of the TreeMap! Just so that I'm sure I understand, it is used to quickly find an rpm based on your distance, right? What are the advantages (if any) of using this instead of plugging your data points into an excel graph and getting a polynomial best fit equation to transform your distance into an rpm?
Unread 09-05-2012, 10:14
Jared Russell's Avatar
Taking a year (mostly) off
The biggest advantage was it made tuning very easy. Take the bot to the practice field with some balls, fire away, and record the range/RPM information into the TreeMap if you like what you saw (we actually had a version of the software that let the operator do this with the push of a "commit" button, but we ended up doing it all by hand just to sanitize the values). No need to fire up Excel.
Unread 09-05-2012, 10:16
By far the biggest advantage of a laptop-based solution was the development process that it facilitated. Simply collect some representative images and then you can go off and tune your vision software on a laptop without needing a cRIO or the FRC control system.
