Go to Post A lot of the time in FIRST it's not what you have when you enter the program, but what you gain from being in it. - Elgin Clock [more]
Unread 15-01-2012, 15:08
ggorsuch ggorsuch is offline
FRC #2471 (Team Mean Machine)
ggorsuch is an unknown quantity at this point
Re: paper: You can do CAN: CAN on a Budget
The pinout of the adapter in this years KoP is different.
These are the colors of the wires that should go to the pins of the DB9 connector:
Blue -> Pin 2
White -> Pin 3
Yellow -> Pin 5
If you use the resistor, it goes on red and green (I haven't found it necessary)
The black wire can be ignored
Unread 15-01-2012, 15:32
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Blue -> Pin 2
White -> Pin 3
Yellow -> Pin 5
noted. you do need the terminator though.
Anybody else able to confirm the pinout? Unlike the db9 adapters from mono price these seem to use the correct color/rj12 color scheme. Unless I hear otherwise, I will promptly edit the document to reflect that.
Unread 15-01-2012, 16:16
ratdude747's Avatar
AKA: Larry Bolan
Good and bad news:
good- all documents have been updated, including the pinout chart
bad- I was only able to upload the .pdf version; the other versions are no longer allowed for upload. I will see if there is a way around the issue, as the editable versions were actually seeing downloads before the filetype ban.
what was changed:
- pinout charts updated to include the 2012 pinouts (thank you ggorsuch for the tip!)
- changed some image formatting in the serial splice cable section
- added references to the 2012 adapter
- made some spelling fixes
- converted the document to Justified alignment to make it look more professional.
as always, comments and suggestions are always welcome.
EDIT- Weekend/build season wise, today happens to be the 1 year anniversary of the document's original writing.
Unread 16-01-2012, 16:15
ratdude747's Avatar
AKA: Larry Bolan
The upload issue has been fixed. All files can be downloaded again.
Also made a few grammar repairs.
Unread 09-05-2012, 02:32
ratdude747's Avatar
AKA: Larry Bolan
I have uploaded an updated version:
- Images converted to lossless JPG compression in the .pdf version.
- Added my new personal logo to the end of the document.
FYI, the revision date didn't change since there text is still the same.
Unread 22-11-2012, 00:38
ratdude747's Avatar
AKA: Larry Bolan
Question: I noticed that IFI is now the producer of the Jags. Has the sites for where BDC-comm and the firmware changed? If so, I'll update the paper to reflect the change (as long as serial Can is legal, I'll support the paper).
