Go to Post Instead of dreading the potential alliance think of ways to impress them so they want you to be part of it! - Koko Ed [more]
Unread 15-05-2012, 17:50
JamesTerm's Avatar
JamesTerm JamesTerm is offline
Terminator
AKA: James Killian
FRC #3481 (Bronc Botz)
JamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to behold
Re: paper: Team 1114 Controls and Programming Overview 2012
Originally Posted by MICHAELABICK View Post
Why would you want to reduce the d constant of PID in certain circumstances for speed PID?
I presume this was the
"Different from standard PID control. Instead of the PID calculation setting
the output, the PID calculation is an adjustment to the output
o output = output + calcPID(currentSpeed)
But if I had to guess, I know that (at least for our power wheel)... the more momentum and kinetic energy built up on higher speeds the less P is needed... but I cannot see yet how that equates to D except that if D is too high it will reverse oscillate. We too had to use a large D though. This attachment is P=4 and D=7. Where magenta is the predicted velocity, Cyan is the encoder velocity, green is the voltage, and yellow is the PID in action.
I'm still trying to master PID... I'd love to get it down to a 2 radian per second tolerance like 1114 has done! We are around 20 radians tolerance.
