Go to Post When you open of CD and you see your very own quote up top, and can't decide if it's a really awesome or "Well...this is awkward..." moment - CalTran [more]
Unread 15-05-2012, 21:00
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: paper: Team 1114 Controls and Programming Overview 2012
Originally Posted by JamesTerm View Post
does the work load impact the kind of curve you will have?
For the Vic, I believe the answer is "yes" (and perhaps significantly) but I have no data to confirm that.
If I am right (that the variation of the Vic's "effective % of full scale output vs input command" curve varies significantly with working load), then it wouldn't make much sense to worry too much about getting the "linearization function" exactly right when the load varies greatly.
Does anyone have such data1 they'd be willing to share?
1 e.g. with a motor connected to the Vic: no-load motor speed vs input command to the Vic, and stalled motor torque vs input command to the Vic. Of course the data for the "stalled motor" curve would have to be limited to small inputs.
