Go to Post This isn't an engineering fair and demonstration, it's FRC. Defense is part of the game. You can't expect a good FRC team to just sit there and get clobbered by a full-court shooter; they're going to engineer a solution to the problem. - Kevin Sevcik [more]
Unread 18-05-2012, 03:57
LeelandS's Avatar
LeelandS LeelandS is offline
Robots don't quit, and neither do I
AKA: Leeland
FRC #1405 (Finney Falcons)
Team Role: Tactician
LeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond repute
pic: 1126 - from 4 Wheel Swerve to 3 Wheel
Unread 18-05-2012, 03:58
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
Re: pic: 1126 - from 4 Wheel Swerve to 3 Wheel
1296 did something similar in 2010 I think...Though I dont think they were able to drive on 3, so if you did, Kudos to you.
How did it pop off?
Unread 18-05-2012, 06:28
LeelandS's Avatar
AKA: Leeland
How did it pop off?
I don't know the specifics, but it got pulled off as we crossed the coop bridge.
Here is a link to the match video. At about a minute, we're crossing the coop bridge. We tip and rock a bit, and then the module falls off as we exit the bridge. I don't know what happened.
We were still able to continue driving. Although we weren't as stable and we were hesitant to drive very much and cross the bridge on 3 wheels.
My heart will forever lie with SparX
1126: 2008 - 2011; Where it All Began.
1405: 2013 - Present; A Wanderer is Born.
Work hard, play hard. And maybe someday...
Unread 18-05-2012, 06:58
ttldomination's Avatar
Sunny
I'm sorry for this, but I must say, "lol".
It was equally amusing/painful to watch a team's shooter fall off. Especially when you watch the drive team go through the emotional roller coaster that is from absolute horror to laughter.
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 18-05-2012, 17:36
GCentola's Avatar
GCentola GCentola is offline
Strategical Tactitian
AKA: Garrick
no team (SparX)
GCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud of
Yeah....that pretty much sums it up.
GO SparX on 3!!!!!
Check us out at:
http://www.gosparx.org
http://www.facebook.com/SparX1126
I Love Two Pencil Designs!
Unread 18-05-2012, 19:12
FRC #1836 (MilkenKnights)
I'm not sure a lot of people know about this, but throughout eliminations, until the finals of LA, 1717 had only 3 of 4 modules working. Eventually, with the extra long finals waits, they were able to replace it. It is really surprising, seeing how they still did so well in those matches, especially because 4 wheel independent requires all modules to be working.
Unread 18-05-2012, 19:19
It's an impressive feat, that's for sure.
However, the 4 wheel independent swerve is actually surprisingly resilient in terms of drive or steering failure (especially if you have code that compensates directly for failure). The use of gyro heading stabilization and/or field centric also greatly help.
The entire module hadn't failed from what I heard; either drive or steering worked. With just one or the other down, it's not too bad.
Unread 18-05-2012, 20:42
RayTurner1126's Avatar
RayTurner1126 RayTurner1126 is offline
team co-lead, mechanical lead
FRC #1126 (SparX)
RayTurner1126 will become famous soon enoughRayTurner1126 will become famous soon enough
we still did drive after we lost the wheel, and we really didn't notice that much of a difference in driving ability as far as what i could see. that's why in the stands we were like "no...that can't be our module...we're still driving!" as for how it happened: the screws holding the module in backed out. we replaced it relatively quickly, so we did have a pretty good laugh about that one....
What time is it?? 11:26!!!
Go SparX on 3!!!
