Go to Post Ban the ingredients for cheesecake, and stores will find substitutes. Remove the market for them, and stores have no reason to make them. - Rachel Lim [more]
Unread 19-05-2012, 08:04
JamesTerm's Avatar
JamesTerm JamesTerm is offline
Terminator
AKA: James Killian
FRC #3481 (Bronc Botz)
JamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to behold
Re: paper: Bronc Botz (3481): LUA script support for Wind River
Originally Posted by connor.worley View Post
Out of curiosity, why did you choose to merge Lua into a single file? The default layout will work without modification.
In short to decrease compile time. We have 54 files (half .h half .cpp) and lua in its original form is 55 files with 23 headers. I have no need to populate the symbol table with any of those headers, and my original goal was to completely eliminate all the symbols from being exported. I was able to take out many of them, but decided to compromise exporting some, so that I wouldn't need to change any functionality. This took a good solid week to achieve. The only symbols I use are written in script.h.
If I left it as it was, EVERY .cpp file would have to access each of the 23 header files, and each file is an I/O operation that costs time. Now then... if anyone knows how to make WindRiver work with precomiled headers, that would change everything, but I've given up trying to figure out if it is even possible. I could then change how I do my includes technique as well.
Oh while I'm here I wanted to post our LUA use case, so that others can see how it works easily. (We use Notepad++ to edit changes on the field):
Here is the LUA configuration used to run on the Admiral II
Code:
Pi=3.14159265358979323846
Pi2=Pi*2
Inches2Meters=0.0254
Feet2Meters=0.3048
Meters2Feet=3.2808399
Meters2Inches=39.3700787
FRC2012_wheel_diameter_in=6   --This will determine the correct distance try to make accurate too
--Parker claimed 20.38, but I've measured 22 5/16
WheelBase_Width_In=22.3125	  --The wheel base will determine the turn rate, must be as accurate as possible!
HighGearSpeed = (427.68 / 60.0) * Pi * FRC2012_wheel_diameter_in * Inches2Meters  --RPM's from Parker
LowGearSpeed  = (167.06 / 60.0) * Pi * FRC2012_wheel_diameter_in * Inches2Meters
KeyDistance_in=144;
KeyWidth_in=101;
KeyDepth_in=48;
HalfKeyWidth_in=KeyWidth_in/2.0;
MainRobot = {
	Mass = 25, -- Weight kg
	MaxAccelLeft = 4, MaxAccelRight = 4, MaxAccelForward = 4, MaxAccelReverse = 4,
	MaxTorqueYaw = 25,
	MAX_SPEED = HighGearSpeed,
	ACCEL = 10,    -- Thruster Acceleration m/s2 (1g = 9.8)
	BRAKE = ACCEL,
	-- Turn Rates (radians/sec) This is always correct do not change
	heading_rad = (HighGearSpeed / (Pi * WheelBase_Width_In * Inches2Meters)) * Pi2,
	Dimensions =
	{ Length=0.9525, Width=0.6477 }, --These are 37.5 x 25.5 inches (This is not used except for UI ignore)
	tank_drive =
		is_closed=0,						--This should always be false for high gear
		show_pid_dump='no',
		ds_display_row=-1,
		wheel_base_dimensions =
		{length_in=27.5, width_in=WheelBase_Width_In},	--The length is not used but here for completion
		--This encoders/PID will only be used in autonomous if we decide to go steal balls
		wheel_diameter_in = FRC2012_wheel_diameter_in,
		left_pid=
		{p=0, i=0, d=0},					--In FRC 2011 pid was 1,1,0 but lets keep i to zero if we can
		right_pid=
		{p=0, i=0, d=0},					--These should always match, but able to be made different
		--This is obtainer from encoder RPM's of 1069.2 and Wheel RPM's 427.68 (both high and low have same ratio)
		encoder_to_wheel_ratio=0.4,			--example if encoder spins at 1069.2 multiply by this to get 427.68 (for the wheel rpm)
		voltage_multiply=1.0,				--May be reversed using -1.0
		reverse_steering='no'
	robot_settings =
		key_1 = { x_in=0				, y_in=KeyDistance_in },
		key_2 = { x_in=-HalfKeyWidth_in	, y_in=KeyDistance_in },
		key_3 = { x_in= HalfKeyWidth_in	, y_in=KeyDistance_in },
		ds_display_row=1,					--This will display the coordinates and heading (may want to leave on)
		ds_target_vars_row=-1,				--Only used during keying the grid
		ds_power_velocity_row=3,			--Only used during keying the grid
		--Currently full power gives around 230ish... so 13 iterations at 200 should be duable (was at .130)
		fire_trigger_delay=0.150,			--Used to wait for a stable rate before engaging the conveyor
		fire_stay_on_time=0.500,			--Used to prevent ball from get stuck during a fire operation (keep small)
		grid_corrections =
			c11={p=1.7, x=1.0}, c12={p=1.7, x=1.0}, c13={p=1.7, x=1.0},
			c21={p=1.9, x=1.0}, c22={p=1.8, x=1.0}, c23={p=1.9, x=1.0},
			c31={p=1.7, x=1.0}, c32={p=1.7, x=1.0}, c33={p=1.7, x=1.0},
		auton =
			move_forward_ft =0.0,
			two_shot_scaler =1.45,
			ramp_left  ={x_in=0, y_in=0 },
			ramp_right ={x_in=0, y_in=0 },
			ramp_center={x_in=0, y_in=0 },
			x_left_arc=1.9,
			x_right_arc=1.9,
			--If you put -1.0 for the timeout wait it will wait infinitely (good for initial testing or if we are not tipping ramps)
			--ball 1 initial wait should be long enough for a good ramp up from zero speed
			--ball_1 ={initial_wait=  2.0, tolerance=75.0, timeout_wait=4.0},
			--ball 2 initial wait should be long enough to recover from dip and short enough to be active during second ball's deployment
			--ball_2 ={initial_wait=0.500, tolerance=75.0, timeout_wait=4.0}
			--panic mode incase the wait ball doesn't work... using zero makes it work like before just pure time
			ball_1 ={initial_wait=  3.5, tolerance=0.0, timeout_wait=-1.0},
			ball_2 ={initial_wait=  3.5, tolerance=0.0, timeout_wait=-1.0}
		turret =
			is_closed='yes',				--It is closed loop when feedback has been properly calibrated
			show_pid_dump='no',				--Only turn on if you want to analyze the PID dump (only one at a time, and it must be closed loop)
			ds_display_row=0,				--Assign to a row (e.g. 0-4) when trying to calibrate the potentiometer
			pid=
			{p=25, i=3, d=2},
			tolerance=0.001,				--we need high precision
			encoder_to_wheel_ratio=1.064,     --Just use the gearing ratios here
			max_speed=10,
			accel=10.0,						--These are only needed if we bind keys for turret
			brake=10.0,
			max_accel_forward=20,			--These are in radians, plan on increasing these as much as possible
			max_accel_reverse=20,
			using_range=0,
			min_range_deg=-180,				--These are probably good to go, but may need to be smaller
			max_range_deg= 180
		pitch =
			is_closed='yes',
			show_pid_dump='no',
			ds_display_row=-1,
			pid=
			{p=1, i=0, d=0},
			max_speed=10,
			max_accel_forward=10,			--These are in radians, plan on increasing these as much as possible
			max_accel_reverse=10,
			min_range_deg=45-3,				--These should be good to go
			max_range_deg=70+3
		power =
			is_closed='y',
			show_pid_dump='n',
			ds_display_row=4,				--Use this display to determine max speed (try to get a good match)
			pid=
			--{p=0, i=0, d=0},
			--{p=0.1, i=0.5, d=0},
			--{p=400.0, i=5.0, d=200.0},
			--{p=400.0, i=75.0, d=200.0},
			--{p=250.0, i=10.0, d=250.0},
			--{p=250.0, i=0.0, d=250.0},   --fall back
			{p=700.0, i=0.0, d=400.0},
			tolerance=17.0,					--we need decent precision (this will depend on ramp up time too)
			encoder_to_wheel_ratio=0.85,     --Just use the gearing ratios here
			voltage_multiply=1,
			square_voltage='no',
			length_in=6,					--6 inch diameter (we shouldn't worry about tweaking this just measure it and be done)
			max_speed=(5000.0/60.0) * Pi2,	--(This is clocked at 5000 rpm) in radians
			accel=200.0,						--These are only needed if we bind keys for power in meters per second
			brake=200.0,
			max_accel_forward=200,			--These are in radians, plan on increasing these as much as possible
			max_accel_reverse=200,			--The wheel may some time to ramp up
			min_range=23 * Pi2				--We borrow the min range to represent the min speed (was 17 as of 3:20 PM 4/21, changed for calibrations)
		flippers =
			is_closed=0,				--Not sure yet about this
			show_pid_dump='no',
			ds_display_row=-1,
			pid=
			{p=1, i=0, d=0},
			tolerance=0.01,					--should not matter much
			max_speed=1.4 * Pi2,			--(Parker gave this one, should be good)
			accel=10.0,						--We may indeed have a two button solution (match with max accel)
			brake=10.0,
			max_accel_forward=10,			--These are in radians, just go with what feels right
			using_range=0,					--Warning Only use range if we have a potentiometer!
			min_range_deg=-90,				--TODO find out what these are
			max_range_deg= 90
		conveyor =
			--Note: there are no encoders here so is_closed is ignored
			tolerance=0.01,					--we need good precision
			voltage_multiply=-1.0,			--May be reversed
			max_speed=28,
			accel=112,						--These are needed and should be high enough to grip without slip
			brake=112,
			max_accel_forward=112,
			max_accel_reverse=112
		low_gear =
			--While it is true we have more torque for low gear, we have to be careful that we do not make this too powerful as it could
			--cause slipping if driver "high sticks" to start or stop quickly.
			MaxAccelLeft = 10, MaxAccelRight = 10, MaxAccelForward = 10 * 2, MaxAccelReverse = 10 * 2,
			MaxTorqueYaw = 25 * 2,
			MAX_SPEED = LowGearSpeed,
			ACCEL = 10*2,    -- Thruster Acceleration m/s2 (1g = 9.8)
			BRAKE = ACCEL,
			-- Turn Rates (deg/sec) This is always correct do not change
			heading_rad = (LowGearSpeed / (Pi * WheelBase_Width_In * Inches2Meters)) * Pi2,
			tank_drive =
				is_closed=0,						--By default false, and can be turned on dynamically
				show_pid_dump='n',
				ds_display_row=-1,
				--We must NOT use I or D for low gear, we must keep it very responsive
				--We are always going to use the encoders in low gear to help assist to fight quickly changing gravity shifts
				left_pid=
				{p=130, i=0, d=180},
				right_pid=
				{p=130, i=0, d=180},					--These should always match, but able to be made different
				--I'm explicitly keeping this here to show that we have the same ratio (it is conceivable that this would not always be true)
		controls =
			Joystick_1 =
				control = "CH FLIGHTSTICK PRO",
				Analog_Turn = {type="joystick_analog", key=0, is_flipped=false, multiplier=1.0, filter=0.00, is_squared=false},
				Joystick_SetCurrentSpeed_2 = {type="joystick_analog", key=1, is_flipped=true, multiplier=1.0, filter=0.00, is_squared=false},
				Robot_SetLowGearValue = {type="joystick_analog", key=2, is_flipped=true, multiplier=1.0, filter=0.0, is_squared=false},
				Robot_Flippers_Solenoid = {type="joystick_button", key=3, on_off=true},
				Robot_SetCreepMode = {type="joystick_button", key=1, on_off=true}
			Joystick_2 =
				control = "Logitech Dual Action",
				--scaled down to 0.5 to allow fine tuning and a good top acceleration speed (may change with the lua script tweaks)
				Turret_SetCurrentVelocity = {type="joystick_analog", key=0, is_flipped=false, multiplier=0.5, filter=0.05, is_squared=false},
				--Ball_Grip = {type="joystick_button", key=2, on_off=true},
				Ball_Squirt = {type="joystick_button", key=1, on_off=true},
				--Ball_Fire = {type="joystick_button", key=4, on_off=true},
				--PowerWheels_IsRunning = {type="joystick_button", key=3, on_off=true},
				Robot_TurretSetTargetingOff = {type="joystick_button", key=6, on_off=true},
				Robot_SetPreset1 = {type="joystick_button", key=5, on_off=false},
				Robot_SetPreset2 = {type="joystick_button", key=9, on_off=false},
				Robot_SetPreset3 = {type="joystick_button", key=10, on_off=false},
				--Until we have the ball sensors working we'll need to re-assign the aim and fire buttons below to use all three button for the grip
				Ball_Fire = {type="joystick_button", key=8, on_off=true},
				PowerWheels_IsRunning = {type="joystick_button", key=7, on_off=true},
				Ball_GripL = {type="joystick_button", key=2, on_off=true},
				Ball_GripM = {type="joystick_button", key=3, on_off=true},
				Ball_GripH = {type="joystick_button", key=4, on_off=true}
			Joystick_3 =
				control = "CH THROTTLE QUADRANT",
				PitchRamp_SetIntendedPosition = {type="joystick_analog", key=0, is_flipped=true, multiplier=1.142000, filter=0.0, is_squared=false},
				Robot_SetTargetingValue = {type="joystick_analog", key=0, is_flipped=true, multiplier=1.142000, filter=0.0, is_squared=false},
				PowerWheels_SetCurrentVelocity = {type="joystick_analog", key=1, is_flipped=true, multiplier=1.0000, filter=0.0, is_squared=false},
				--This top one is only for open loop mode, and works like the game pad
				--Turret_SetIntendedPosition = {type="joystick_analog", key=2, is_flipped=true, multiplier=0.5, filter=0.1, is_squared=true},
				--Turret_SetIntendedPosition = {type="joystick_analog", key=2, is_flipped=true, multiplier=1.0, filter=0.1, is_squared=false},
				Robot_SetDefensiveKeyValue = {type="joystick_analog", key=5, is_flipped=true, multiplier=1.0, filter=0.0, is_squared=false},
				--Ball_Fire = {type="joystick_button", key=6, on_off=true},
				--PowerWheels_IsRunning = {type="joystick_button", key=4, on_off=true},
				Robot_SetDefensiveKeyOn = {type="joystick_button", key=11, on_off=false},
				Robot_SetDefensiveKeyOff = {type="joystick_button", key=12, on_off=false},
				Ball_GripM = {type="joystick_button", key=4, on_off=true},
				Ball_GripH = {type="joystick_button", key=6, on_off=true},
				PowerWheels_IsRunning = {type="joystick_button", key=8, on_off=true},
				Ball_Fire = {type="joystick_button", key=10, on_off=true}
	--This is only used in the AI tester, can be ignored
	UI =
		Length=5, Width=5,
		TextImage="(   )\n|   |\n(   )\n|   |\n(   )"
Robot2012 = MainRobot
