Go to Post If you want to make change, you have to know what you're trying to change. - [more]
Unread 24-05-2012, 17:11
Re: paper: 987 Kinect Implementation
Originally Posted by Hjelstrom View Post
If anyone can point us in the direction of a way to stream video (stream the frames that the kinect code renders) from the Pandaboard/Ubuntu to the SmartDashboard, that would be a huge improvement for this kind of control system. That would be a good offseason project.
If the stream is a true stream, then this may be of help ... if you can't write code/scripting to make a stream of your own, then see below. ffmpeg (on linux) may help create a stream; it's pretty versatile, but I've only used it to convert youtube videos into local files.
www.videolan.org
Otherwise, you may wind up wrapping the images and then coming up with a simple Java display that displays the latest image from the socket. We did this in 2009 & 2012. It's another layer of complexity, so I'd recommend trying to get a video stream going first.
GitHub
