Go to Post FRC2010 - The flying purses :P - Bharat Nain [more]
Unread 31-05-2012, 22:38
Peck's Avatar
Peck Peck is offline
worse then failing: proving murphy
FRC #1619 (Up-A-Creek Robotics) and FTC # 4633)
Peck will become famous soon enough
Re: pic: Robot cart design
Originally Posted by Camren View Post
Preferably aluminum but i'm unsure how it will handle the abuse so possibly steel.
if aluminum can't take the abuse of being a robot cart, you should take another look at your design. Steel will, in all likelihood, hurt more then it will help.
For example (over engineering it): If your robot weighs 200 lbs and you have 4 support beams holding that weight, then each beam will receive (ideally) 50 lbs. Basic mechanical physics tells use that the beams will be receiving a compression from the weight. Go to your school (or local) lifting room and put a 50 lbs weight (or 50 lbs equivalency) on the top of some aluminum of about the dimensions you want to have for your support beam. If it notices the weight at all then beef it up.
Cad, Electrical, Machining, Debugging (old school), PR, Distraction elimination
TEAM 1619
__UP-A-Creek Robotics__
It ain't done till it's over-done
