Go to Post And when the President of the United States is playing with LEGOs and getting down on the floor to look inside of robots, then I would have to say "Mission Accomplished". - OZ_341 [more]
Unread 01-06-2012, 05:45
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
slijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to behold
Re: pic: Robot cart design
Originally Posted by Peck View Post
if aluminum can't take the abuse of being a robot cart, you should take another look at your design. Steel will, in all likelihood, hurt more then it will help.
For example (over engineering it): If your robot weighs 200 lbs and you have 4 support beams holding that weight, then each beam will receive (ideally) 50 lbs. Basic mechanical physics tells use that the beams will be receiving a compression from the weight. Go to your school (or local) lifting room and put a 50 lbs weight (or 50 lbs equivalency) on the top of some aluminum of about the dimensions you want to have for your support beam. If it notices the weight at all then beef it up.
Most aluminum isn't that weak. Do take careful note of which alloy you use, because depending on the abuse your cart takes, that will make a difference.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
