Go to Post Lose lips sink... robots? (during a water game at least) - Zach O [more]
Unread 04-06-2012, 10:37
Data Nerd
FRC #0079
Re: [MCC] Minimum Comptetivie Concept 2011
The minibot was the obviously most vital part of the game. But it was quite, quite expensive to prototype and iterate your way to a direct drive minibot with a solid reliable deployer. Every time your prototype blew a motor, $30 down the drain. Yes, you could work on it after ship, but without a robot to look at and to figure out mounting, dimensions, etc., unprepared teams (I.e. those doing the MCC) had an uphill battle. Yet, at the early regional level, just having a semi reliable minibot made you an instantly decent robot. So I'm tempted to say the best "MCC" is a Kitbot on Steroids with a minibot on top of it.
Note - Thank you Ian Curtis for running these numbers...
http://ewcp.org/blog/2011/12/08/aver...-to-your-team/
In 2011 your MCC (I typically use the term MVP for Minimum Viable Product) was a kitbot (on or off steroids) and a minibot system. If you look at the average team they scored just over 10 points. Couple this with 33% of matches not having a single minibot go up and 76.7% of matches didn't have both alliances send a minibot up. Honestly, if you send any minibot up every match you will end up with max points 33% of the time and probably second place the rest of the time. This would have put you well in the top 50% of teams if not higher.
TL;DR - doing something reliably is better than doing something well occasionally.
Unread 04-06-2012, 17:36
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
As an aside, note that when I say average in that post I meant mean. So the median robot (which is really what you care about, as at a large event the median robot will be roughly the last robot selected for eliminations) will be less good at scoring than the mean robot. As can be seen in Jim Zondag's data, robot scoring ability has a decidedly positive skew.
tl;dr: The numbers in my blog post above are over-estimates of how many points the median robot scored. And the median is likely what you are aiming for if you wanted to make elims as a 2nd pick at most events.
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
Unread 05-06-2012, 09:37
JesseK JesseK is online now
I think one point that's been anecdotally eluded to in these two threads (yet not quite outright stated) is that the MCC should be designed for the specific Regional(s) a team will attend.
A Regional with 32 teams is a vastly different competition environment than a Regional with 64 teams (though such a low team count at a non-District event was uncommon this year). Getting good at the one thing that differentiates a MCC-team from the rest of the pack may not matter as much at the 64-team Regional since there could be plenty of teams who can do more than "MCC".
So would the MCC-team's strategy have to change for a small regional versus a large?
GitHub
Unread 05-06-2012, 11:03
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
A repeatable minibot for 2011 would have been good at Granite State Regional (53 teams with a lot of high quality teams).
http://www.thebluealliance.com/event/2011nh
Quarters 1 often give good insight as you have #1 alliance against #8. #1 seeded highest and gets 1st pick. #8 was the quality of the lowest ranked captain and is picking what should be roughly the #16&#17 best robots at an event. since they are the last captain, the teams they are picking can't say no and still compete. Seeing what makes up a #8 alliance is to me a good indicator of what it takes to be a Captain and to get picked at an event. If you watch the quarters at this event, a repeatable mini-bot (as long as it makes it up in scoring time) would have been a good pick.
New Jersey, a 64 team event would seem to confirm the same logic:
http://www.thebluealliance.com/match/2011nj_qf1m1
At a qualified event like MSC, MAR Championship, World Championship, an MCC will likely run in to more difficulty, but those are distinctly different then the stated goal of playing in Elims at District or regional events.
Last edited by IKE : 05-06-2012 at 11:53. Reason: added opinion on "qualified" events
Unread 05-06-2012, 11:48
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
It was! Our minibot went up the pole 8 times in 10 matches (the two it didn't were when we were pushed away from the pole and one where we never moved due to a sidecar problem). Of those eight launches seven were first place and one was a close second! We had a pretty MCC robot for 2011. It was a kitbot on steriods (6wd plaction wheels with AMshifters) and a single jointed arm with a pinch claw for the low row. We averaged around 2-5 low tubes a match and a minibot all weekend and were the first pick by the 5th seeded alliance. Our low row tubes proved to be quite useful in matches as we were typically the primary scorer for our alliance and beat an effective tube scoring alliance in match 38 by one point!
Our 2011 record can be found here. Notice how the average score for our alliances were around 30 points (excluding match 32 from sidecar problems).
A video of one of our better matches at GSR can be found here!
At the Championship we mainly played defense, tube scoring, and 1s minibot.
1058 PVC Pirates 2016 - xxxx
Unread 05-06-2012, 15:01
Clinton Bolinger's Avatar
Clinton Bolinger Clinton Bolinger is offline
FF - PureMichigan
FRC #2337 (EngiNERDs)
Clinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond repute
MCC = Juggernauts (@Kettering District)
A robot that is designed to be a MCC would be the following:
- KoP Chassis
- Simple Arm that lowers to pickup tubes from the floor
- Full Width Roller Claw
Basically a feeder bot. Many times the first round pick robots would be picked for their scoring ability or their minibot. Many teams would over look robots that could feed tubes well to have a third mediocre scorer or minibot. Also there was a strong correlation between good scorers and good minibots, typically if you had one you had the other.
For the "M" in MCC, I would say that making a good consistent Minibot was a very difficult task for most teams let alone a team that is building a MCC.
-Clinton-
