Go to Post The future is a dark and mysterious place, and trying to force our current methods on that are patently absurd. - Taylor [more]
Thread Tools Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
Unread 15-06-2012, 17:19
Bryscus's Avatar
Bryscus Bryscus is offline
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Bryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud of
Re: paper: Team 341 Vision System Code
So after attending the Einstein Weekend debugging session this past weekend and chatting with some of the teams about their various OpenCV implementing vision systems, I just HAD to check out Daisy's code (another suggestion from Brad Miller).
So honestly, I have little experience with Java but figured what the heck since it's so close to C++. After following some of the Getting Start Guides and playing with a couple of projects, I downloaded Daisy's code and set to work running main() and passing the example image paths to the code as arguments. This seems to work well and two windows pop up showing the "Raw" and "Result" images. What baffles me is that I get this as output as well:
"Target not found
Processing took 24.22 milliseconds
(41.29 frames per second)
Waiting for ENTER to continue to next image or exit..."
and for the "Result" image I get a vertical green line more or less in the middle of the picture. I ran the program a couple of times with different images and similar results? Can someone tell this C guy what the heck he's doing wrong? Is there something I'm missing? If you guys (Daisy) were using a different color ring light or something, could you provide some sample images that work? Thanks in advance!
- Bryce
P.S. I'm running this on an OLD POS computer running XP and a Pentium D processor. I'll have to run it at home on something with a little bit of muscle and check performance.
The opulence of the front office decor varies inversely with the fundamental solvency of the firm.
Unread 16-06-2012, 16:35
Jared Russell's Avatar
Taking a year (mostly) off
The vertical green line is simply an alignment aid that is burned in to each image - it is not an indication that you have successfully detected the target. If the vision system is picking up the vision targets, you should see blue rectangles and dots indicating the outline and center of the targets, respectively.
Which images are you testing with? The supplied images should work with the code "as is". If you are using your own images, are you using a green LED ring? If you are using a different color LED ring, you will need to alter the color threshold values in the code. Note that regardless of LED ring color, adjusting the camera to have a very short exposure time (so that the images are quite dark) increases the SNR of the retroreflections, and makes tracking both more robust and much quicker.
