Go to Post Maybe someday soon the quote will be, "As American as baseball and FIRST robotics!" - KathieK [more]
Unread 26-06-2012, 10:25
androb4's Avatar
androb4 androb4 is offline
..is trying to take this year off.
AKA: Andrew A.
androb4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to behold
Re: pic: How's this?
Sorry for not posting any info.. It was getting late.
All the aluminum is 1/8" thick, 6061 T-6
The 8" FIRST shell is sitting on a 1/2" keyed shaft with AM hubs
That is spun by 2 Fisherprice 9015 on Banebots P60's 4:1
The shaft is supported buy the two inside pieces of C channel extrusion with bearings set in the wall.
Next is a shaft coupler to attatch it to the P60's, which are mounted between the walls of another C channel extrusion.
The ball compression is about 1.5"-2"
The camera mount IS 1/8" sheet metal.
This is my first time using sheet metal like this so I'm not sure about the best thickness to use.
Yes the disk is used for a tachometer. There is a Rockwell Automation Photo sensor under the left P60.
The hood is made of the AM hex tube from the chassis kit, space about 1"
ONE thing I need help with is, riveting. What size whole and what rivets should I use for the camera mount? Any suggestions? Also for attaching the sides of the hood the the square tubing on the outside.
FRC 441 Mentor 2012-2015
FRC 441 Alumni 2009-2012
FTC 4673 Alumni 2011-2012
FRC 1484 Alumni 2006-2008
