Go to Post I'm not gonna reinvent the wheel cause I can already buy it :) - Stephen Kowski [more]
Unread 26-06-2012, 22:09
Nate Bloom's Avatar
Nate Bloom Nate Bloom is offline
FRC #1410 (Kraken)
Nate Bloom will become famous soon enough
pic: Chameleon Drive
Unread 26-06-2012, 22:10
LeelandS's Avatar
LeelandS LeelandS is offline
Robots don't quit, and neither do I
AKA: Leeland
FRC #1405 (Finney Falcons)
Team Role: Tactician
LeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond repute
Re: pic: Chameleon Drive
Wow. I'm not much of a mechanic, but I find this concept EXTREMELY interesting. Very well done.
I love the potential versatility! Any chance this would get built so we can hear about it in practice?
My heart will forever lie with SparX
1126: 2008 - 2011; Where it All Began.
1405: 2013 - Present; A Wanderer is Born.
Work hard, play hard. And maybe someday...
Unread 26-06-2012, 22:23
akoscielski3's Avatar
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
Interesting Concept.
Would you always leave the extra bearing blocks inside the chassis or would you take them out to save weight? how easy is it to get at the transmissions and wheels if you wanted to change them?
2013-Present
Team 772 Sabre Bytes
2010-2013
Unread 26-06-2012, 22:36
Peck's Avatar
Peck Peck is offline
worse then failing: proving murphy
FRC #1619 (Up-A-Creek Robotics) and FTC # 4633)
Peck will become famous soon enough
What size wheels are max and min for each set up? how strong is it? how heavy is it?
as i see it right now, it's worth looking at for a test chassis or demo bot but not for an actual competition bot.
Cad, Electrical, Machining, Debugging (old school), PR, Distraction elimination
TEAM 1619
__UP-A-Creek Robotics__
It ain't done till it's over-done
Unread 26-06-2012, 22:56
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
Changing from hex to keyed shafts only reduces costs if you don't value your repair time at competition.
Unread 26-06-2012, 23:28
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
I love this idea, very versatile. You can argue that the same things can pretty easily be done with the kit chassis.
Is there a reason for not centering the gearbox and motor assemblies? It's a minor thing but it makes your COG much nicer. Also I don't really see the need for the second omniwheel for strafing on the slide drive. I guess it makes you faster at it but not really worth the weight of the wheel, motor, and gearbox especially cause you can use a CIM somewhere else on your robot by not using it there.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 26-06-2012, 23:55
Nate Bloom's Avatar
FRC #1410 (Kraken)
I apologize in advance for this massive response, I just wanted to address everyone's questions/comments.
Thank you, we will hopefully build this as an off-season project to test its viability, in which case I will post results.
I feel that it would be better to leave them in because it allows for faster changes between drives. I intentionally left out anything on the bottom of the robot, with the idea that we could raise the robot and have easy access to the necessary bolts under it. This would theoretically mean that switches could be very quick with a few people.
4WD: 4''-10''+
6WD: 4''-10''
8WD: 4''-8''
10WD: 4''-6''
Omni: 4''-8''+
I would be cautious about 4'' wheels however, due to the three inch bars. The strength is hard for me to predict, but it is entirely .125'' aluminum and bolts. The weight should be about 30 lbs, but there is a lot of estimation in that.
Right now it is very much in the conceptual stage, and hopefully we will build it as a test chassis to determine its viability.
Really? Our team doesn't have much experience with direct drive, so I hadn't assumed much of a difference.
I feel that the big advantage this has over the kit chassis is that it allows easier access and switching between these different drives without modifying the frame itself at all.
As far as the centering, it was simply difficult to accommodate for a dropped or flat wheel with the gearbox also attached.
I debated the second omni wheel for a while, so version 10 might be able to accept either 1 or 2 strafing omnis. That's definitely back up on the consideration list, thanks.
Unread 27-06-2012, 00:07
Gray Adams's Avatar
I'm not saying the chassis is a bad idea, I actually really like it.
We had a grand total of one keyed shaft on our robot this year. We lost the key half a dozen times. Sure you could put more effort into the design and build such that it isn't an issue, but hex is just simpler, more easily repaired and maintained.
The bearings are a bit more expensive, but you could not convince me to go back to keyed shafts. More pieces, less strength, harder to deal with over all. The only advantage is that you can use round bearings (without using a sleeve), which are extremely common and widely available.
I'd really like to try out a drive system that goes 1/2" hex -> 1/2" round -> 7/16" hex. It would be a bit of a luxury, but not unreasonably so (especially if you have a machining sponsor to save you the cost of the necessary tools if you don't have them).
Unread 27-06-2012, 00:12
IanW's Avatar
IanW IanW is offline
Rookie Mentor
AKA: Ian
FRC #0997 (Spartans)
Interesting idea. Just a couple suggestions:
Unless you are planning to weld this, I'd suggest beefing up the gussets between the siderails. Add a few more rivet/bolt holes to them, especially on the insides.
With cantilevered wheels like this, I'm not sure if having the sprockets on the outside of the wheels would be the best idea. If you can figure out how to move them to the inside of the chassis or even to the other side of the wheels without violating your design goals, I'd recommend it.
Finally, I don't think it should actually be used for competition. If you use it for preseason R&D, the modularity could be beneficial, but for competition, choosing one design and sticking with it is almost certainly better. This way, you don't have to make concessions on other parts of your robot just to accommodate this drivetrain.
All told, very nice job for your first CAD project. Keep taking on new projects - it's an excellent way to get better.
Website
Facebook
Unread 27-06-2012, 01:19
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Cool idea. Although I like the concept, I feel like weight might become a bit of an issue. You have to carry around all that plate and bearings even if you never use them.
Also, do you have any plans for bumpers? These tend to get left out in most drive train designs until the end. You may have trouble supporting the bumper to what the manual requires (I believe every ten inches) with the three bearing blocks in a row.
-Plutarch
Unread 27-06-2012, 08:43
"Chameleon Drive" implies the thing blends into the background ... yet I totally see all of that drive in all configurations o.O
(Ok, I kid...)
The most basic piece of this 'drive' is the H-frame. Your H-frame setup is very verstatile. However, I don't think the gearbox configurations are. For the 8WD and 6WD tank variants, why not just use the CIMple boxes that come in the KOP? The chain runs are easily tensioned by sliding the transmission, it's lighter overall, c.g. is lower overall, and the sprocket reductions are adjustable so you aren't stuck with purchasing ~$100 in gears just to get the right speed for a given year.
For the slide drive (your bottom pic), you may find that the robot doesn't need to slide sideways as fast as it moves forward/back. If this is what you find, you may be able to use 2 RS-550's (properly geared...) in lieu of 2 CIMs, thereby putting the 2 CIMs back on the outer wheels for better power characteristics during normal play.
GitHub
Unread 27-06-2012, 10:20
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Two thoughts on what looks like a great design:
- For use as a test chassis, how about emulating AndyMark's nano tube chassis and running power between the wheels inside the frame? That way, you could have every wheel slot powered all the time, making swapping drive trains even easier (just pull off one set of wheels and put on another!)
- If you want to use this for competition, keep the weight rules in mind. Swappable systems like this are really cool, but all of the hardware used in every configuration you bring counts towards your weight limit. So, if you plan to swap between traction and omni wheels at competition, you'll have to weight both sets of wheels with your robot, even though only one set will be on the robot at a time. See R03 in the 2012 game manual for specifics (it's been in the manual that way for years, I doubt the rule will change in the future).
Unread 27-06-2012, 10:39
One more thought... why not push the two cross bars towards the outside a bit more, and set them up for 3 wheels each? That would give you the option of using the center for a strafing wheel like you have now, or setting it up for a wide drive base design, with no wheels on the long side.
Unread 27-06-2012, 11:03
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
Looks pretty cool.
A few comments:
1. Figure out your bumper mounting. This is something most people ignore until the "end" but the sooner you think about it the happier you'll be with the implementation.
2. I've found the 6" diameter AndyMark omni-wheels work a lot better when they're run as duallies -- you should consider that for your H-Drive implementation.
3. I believe you're sacrificing some functionality at the expense of versatility. "Jack of All Trades, Master of None." In my experience, it is very very very rare for a team to switch drive styles mid-season. As a result, it might be better for you to CAD several different configuration specific designs, knowing that you'll be able to do subtle things to make them better than this one design that does all of them. If you prioritize versatility enough that you're willing to make tradeoffs (they may be big, they may be small) then you have nothing to worry about. Your mileage may vary.
-John
Unread 27-06-2012, 13:21
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Very cool design. I agree with a lot of the other commenters that this looks like a really neat and versatile test chassis. I would suggest talking with your programmers about sensor incorporation and programming goals. A chassis like this could go from good to great with good iterative software and driver interface development.
Even if it is a test chassis, the addition of good bumper should enable you to have a defensive sparring partner.
