Go to Post Our team's worst moment was the 13 years of FIRST's existence in which it did not exist. - Joe G. [more]
Unread 27-06-2012, 15:05
Peck's Avatar
Peck Peck is offline
worse then failing: proving murphy
FRC #1619 (Up-A-Creek Robotics) and FTC # 4633)
Peck will become famous soon enough
Re: pic: Chameleon Drive
one more comment: where are you putting your speed controllers and other nessesary hardware?
Cad, Electrical, Machining, Debugging (old school), PR, Distraction elimination
TEAM 1619
__UP-A-Creek Robotics__
It ain't done till it's over-done
Unread 27-06-2012, 15:36
Nice first full project, Nate. Here are a couple things you can check out to help you iterate; another person a while back had a similar idea.
http://www.chiefdelphi.com/forums/sh...ad.php?t=95179
http://www.chiefdelphi.com/media/photos/36921
As with the above project, it could be a great project to make in the offseason to test different drives, but it most likely is not the practical design for a competition robot.
Also, this may be a good chance for you to learn how to create configurations of your assembly within Solidworks.
Unread 27-06-2012, 15:42
Garret's Avatar
Garret Garret is offline
AKA: Garret Smalley
We switched from swerve to Mecanum at the LA Regional this year; this was because we accidentally fried our swerve steering motors when calibrating the PID at San Diego and didn't want to deal with it at LA. We were able to do this very fast because we design our drive train in modules. Each module uses the same of mounting and has everything already built in (except controllers).
I really like a of things about the the OP's design, especially the design around limited manufacturing capabilities. Also, it looks like it should be able to accept mecanum as well because of the corner gearboxes. Great work!
7 Years of FRC
Unread 27-06-2012, 17:31
mikemat mikemat is offline
mikemat has a spectacular aura aboutmikemat has a spectacular aura aboutmikemat has a spectacular aura about
Just out of curiosity, how much time do you think it would take to change the drive types? It would add a neat dynamic if you could be a 6- or 8-wheel drive for quals, then switch to mecanums or a slide drive in elims so you can triple, or change drives between matches to better suit your opponents and partners.
Unread 27-06-2012, 17:44
Peck's Avatar
dude, you would take up your entire weight allowance in just the drive train and be unable to master how the robot drives.
TEAM 1619
Unread 27-06-2012, 18:07
If you shipped as pictured in 6 or 8wd configuration, all you would need to bring would be the mecanum wheels. A slide drive would be harder because you would need an extra gearbox and motor controller, but not impossible with 30 pounds. I can't speak for driver training, but judging from the teams that already switch mid season, it isn't impossible to adjust to a different drive.
Unread 27-06-2012, 18:24
EricH EricH is offline
Modular systems are allowed on a robot, but if a robot can have extra configurations--example, two arms that have different functionality--either you stick with one configuration (or do a permanent change and request reinspection) or all the configurations together must be under the weight limit. That's been in the rules for as long as I can remember.
The governing limit here isn't the Withholding Allowance. It's the robot weight. I don't think that most teams would like cutting into the 120# allowance by 15# or more.
However, I think this sort of drive system could be invaluable to a team, not necessarily in competition use but as a practice robot. Build it Day 1, throw a bunch of tests at it to figure out drive base for the year, use as a practice defender or build the rest of the robot on top of it. It's not unheard of for a competition robot to be designed to handle two different types of drivetrain, but only use one in competition.
Unread 28-06-2012, 17:04
mschwab013's Avatar
mschwab013 mschwab013 is offline
AKA: Matt Schwabenbauer
FRC #0291
mschwab013 is a name known to allmschwab013 is a name known to allmschwab013 is a name known to allmschwab013 is a name known to allmschwab013 is a name known to allmschwab013 is a name known to all
This is so cool! Can you possibly send me the CAD file so I can show it to my team and we might try and build a prototype of it to see how well it works
2013 Pittsburgh- Gracious Professionalism award, 7th seed, 6th alliance captian, quarter-finalist(291,3492,4601)
2013 Queen CIty- Chairman's Award, 39th seed
2012 Pittsburgh- 23rd seed
2012 Buckeye- 34th seed, 2nd alliance, quarter-finalist(291,1241,4085)
2011 Pittsburgh- 13th seed, 5th alliance, quarter-finalist(291,337,3504)
2011 Buckeye- 18th seed, 8th alliance, quarter-finalist(279,291,3496)
2010 Finger Lakes- 15th seed, 5th alliance, quarter-finalist(291,1507,1559)
2010 Buckeye- Chairman's Award, Imagery Award, Quality Award, 4th seed, 1st pick, 1st alliance, semi-finalist(291,1014,1629)
Unread 29-06-2012, 15:09
Nate Bloom's Avatar
Nate Bloom Nate Bloom is offline
FRC #1410 (Kraken)
Nate Bloom will become famous soon enough
Again, thanks for all of the comments and suggestions! I am taking all of this into consideration with version 10, so this has been a huge help.
Originally Posted by IanW View Post
All told, very nice job for your first CAD project. Keep taking on new projects - it's an excellent way to get better.
Thanks, I have been in leadership except for my freshman year, so once in a while it is nice to get back to what I really love about robotics.
I was hoping to leave the bottom free, but I will try to work around integrating the electronics in the chassis with version 10, especially since we are likely first building this as an independent chassis.
I was actually inspired by 159's description of their bearing blocks on their final robot. I hadn't realized that it was originally such an adaptable frame, and I only saw them use 8WD in competition.
I tried to keep everything simple and easily accessible, with the idea of changing sets between quals and elims, or maybe even between matches in mind. That said, it may be more difficult accounting for weight and having a driver trained for both drives, as others have mentioned.
