Go to Post Rules are after all rules. They don't have to make sense. - ChrisH [more]
Unread 16-07-2012, 21:13
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
pic: More fooling around with mecanum wheels
Unread 16-07-2012, 21:54
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: pic: More fooling around with mecanum wheels
Yes, a three inch mecanum wheel would be a bit ridiculous, a wheel of any type smaller than 4 inches is rare in FRC.
On another note, you should consider how you are mounting these. Mecanum drives do weird things when any of the four wheels lifts off of the ground so some sort of suspension is recommended.
Unread 16-07-2012, 22:10
Yes - it's not a serious proposal. Just got to thinking about it and wondered what it would look like.
Unread 16-07-2012, 22:12
MattC9's Avatar
MattC9 MattC9 is offline
Have you tried shifting with mech's befor?
Unread 16-07-2012, 22:21
We did a mini-octocanum drive last year and had mecanums with fixed raised wheels for climbing the ramp in 2010. We've never done a shifting version. (The mini wheels were 2" diameter Colsons.)
Unread 16-07-2012, 23:24
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
What is mini-octocanum? Is it standard octocanum with smaller "tank" wheels?
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 17-07-2012, 03:39
Yes. Since we wanted a wide robot there wasn't much room for the second set of wheels. We tucked 2" diameter Colson wheels in as close as possible to the 6" mecanum wheels.
Here is a picture of the module. It worked really well except for being rather heavy. (The frames were aluminum not Lexan.) If we did it again, we'd work on bringing the weight down.
Unread 17-07-2012, 03:49
GRT808's Avatar
GRT808 GRT808 is offline
AKA: Grant
FRC #3008 (Kalani Falcons)
GRT808 is just really niceGRT808 is just really niceGRT808 is just really niceGRT808 is just really nice
What CAD software is this?
Personally, I am interested in what you did you color the bearings. I haven't been able to make them look like the shiny metal bearings you have.
Very nice render!
2009 Hawaii Regional Rookie Inspiration Award
2010 Hawaii Regional Chairman's Award
2011 Hawaii Regional Entrepreneurship Award
2012 San Diego Regional Entrepreneurship Award
2012 Hawaii Regional Entrepreneurship Award
2012 Hawaii Regional Chairman's Award
2012 World Championship Judges Award
Unread 17-07-2012, 04:55
Very nice render!
We use Creo. I made the bearings chrome. The other parts are aluminum, steel, brass, plastic, etc. Creo has lots of material choices and then choices for each material. For example, under the aluminum choice you can pick brushed, anodized blue, anodized red, cast, matte, polished, satin or scratch. The room for rendering is set to glossy white plastic.
Unread 17-07-2012, 06:58
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Tom, you're the man. You make some really sweet models, even if you're just fooling around with some of them.
Unread 17-07-2012, 11:53
JesseK JesseK is online now
If the wheels were 2.5" instead of 3", I'm not sure why this is infeasible at a first pass. I think this design would be robust enough for a FRC bot on a flat field under 2 conditions: 1.) The lexan that supports the outer edge of the dead axle were replaced with C-Channel and 2.) The robot frame only mounts to the C-Channel.
3"x1.5" C-channel with 0.2" leg thickness would work great. The added ounces of the Aluminum C-Channel would be offset by leaving the gearbox plates as polycarbonate. All robot impact forces resolve through the C-Channel, and the polycarbonate only needs to be strong enough to rigidly cantilever the CIM as shown.
GitHub
Unread 17-07-2012, 12:16
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Hi Tom,
I'm interested in the rollers.
Could you post a spreadsheet (or a text file) of the roller contour profile (roller radius vs position along roller axis). Thanks.
Unread 17-07-2012, 14:50
Hi Tom,
I generated the profile in CAD. I took a 3" diameter circle and projected it onto a plane tipped at 45 degrees. Then I played with the roller center line to get a roller size that fit nicely. I set the width of the roller so that the end of one roller was in line with the start of the next roller.
Unread 17-07-2012, 21:29
GRT808's Avatar
AKA: Grant
Is this with Creo Parametric? How long did it take you to render this? As for the bearings, did you color them entirely chrome? Or did you color them any additional colors (for example, different faces different colors, etc).
Unread 17-07-2012, 22:05
It's Creo Elements/Pro (Wildfire 5.0). I didn't time the render but I believe it takes maybe 45 minutes or an hour. I do a draft render first that only takes a couple of minutes and if everything looks good I put all the settings to maximum for the final render. The bearings are just chrome but other parts have multiple colors. If you look closely at the nylock nuts you may be able to see the nylon inside the nut.
