Go to Post You can lead a horse to water but you can't make it drink. Our job is to make the horse thirsty. - Andrew Schreiber [more]
Unread 18-07-2012, 17:33
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: paper: RC Servo Signal Generator
There was a small error in the Code Examples so I updated that file.
I also uploaded a complete working demo program (full source code) that can serve as a starting point for creating your own app. Just add a user interface. Or, you can just use the TP7 IDE as the user interface.
Remember: this program works properly ONLY on DOS machine, where the app has full and exclusive control of the machine and direct access to the hardware.
It will not work properly in a "DOS Window" under Windows.
