Go to Post That's one of the saddest stories I've ever heard. When your green isn't neon enough, you are in big trouble in FIRST. - JaneYoung [more]
Unread 19-07-2012, 12:54
jakemochas jakemochas is offline
Programmer
FRC #1717 (The D'Penguineers)
Team Role: Student
jakemochas has much to be proud ofjakemochas has much to be proud ofjakemochas has much to be proud ofjakemochas has much to be proud ofjakemochas has much to be proud ofjakemochas has much to be proud ofjakemochas has much to be proud ofjakemochas has much to be proud ofjakemochas has much to be proud of
pic: 2012 1717 Wheel Module Photo 2
Unread 19-07-2012, 12:55
Andrew Lawrence
Re: pic: 2012 1717 Wheel Module Photo 2
What speed were you geared for?
Unread 19-07-2012, 17:47
42!'s Avatar
42! 42! is offline
College Student
42! is an unknown quantity at this point
Why was it that you choose to use custom gears for the Rs-550 reduction over banebots planetary gearboxes? Was there any weight saving this way?
Unread 19-07-2012, 21:08
Am I correct in saying the 550 is being used just for steering?
Unread 19-07-2012, 21:15
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Thanks for putting this picture up - this is REALLY cool look at. Very impressive.
Last edited by Nemo : 19-07-2012 at 21:18. Reason: Original statement was wrong. Oops.
Unread 19-07-2012, 21:20
You are correct, as you can see in this picture http://www.chiefdelphi.com/media/img...614b368a_l.jpg
Unread 19-07-2012, 22:54
Gdeaver Gdeaver is online now
FRC #1640
We used the banesbot trans for steering and do not like the back lash they have. I wonder if this approach has less back lash? I notice the wheel position sensor is not in the pictures. What sensor did you use.
Unread 19-07-2012, 23:08
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
This is a really neat module!
-RC
R.C.
MadTown Robotics Team 1323
Unread 19-07-2012, 23:14
Do you mean a sensor for the rotation of the module? I believe it is pictured in the black bracket in this picture http://www.chiefdelphi.com/media/img...3a6d3087_l.jpg
Unread 19-07-2012, 23:36
FRC #1640
Looks like the sensor mount and a coupling but, what sensor was used. It does not appear that the timing belt pulleys are 1:1 so I'm guessing a quadrature encoder?
