Go to Post "It's not a bug, it's an unlisted feature." - Barry Craig [more]
Unread 27-07-2012, 08:39
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
pic: Shielded Encoder Cable 1
Unread 27-07-2012, 08:40
Nikhil Bajaj Nikhil Bajaj is offline
MATLAB Fan
Nikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond repute
Send a message via AIM to Nikhil Bajaj
Re: pic: Shielded Encoder Cable 1
Don't forget to ground the shield wire! Otherwise it won't work as well!
Unread 27-07-2012, 09:17
Aren Siekmeier's Avatar
on walkabout
Heh, I first read that as "shield the ground wire," but it turns out you're actually saying something useful
I like the idea. What does the end shown interface with? It wouldn't be able to reach signal pins and power/ground pins on the DSC at the same time... (assuming that's 100 pitch housing in the first place) I see now the thread this pertains to. Cool.
Unread 27-07-2012, 09:18
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
He addressed that here:
Originally Posted by KrazyCarl92 View Post
The aluminum foil is twisted at one of the ends of the cable, and grounded to the source ground (the jaguar 5 pin connector's ground in this case). It is important to only ground one side of the cable and not both, otherwise you could create a closed circuit, which may cause EMI if there is current going through the foil. My sources say you could also get away with grounding to the frame, but I don't think this is legal and it is usually better practice to ground it to a source anyway.
Unread 27-07-2012, 16:14
DonRotolo's Avatar
Back to humble
FRC #0832
And ground it only at one end, lest you induce a ground loop. In genral, practice is to ground it at the controller end, not the sensor end.
