Go to Post If you're the smartest person in the room, you're in the wrong room - Ian Curtis [more]
Unread 30-07-2012, 22:49
steelerborn's Avatar
steelerborn steelerborn is offline
Engineer at JBT FoodTech
AKA: Jonathan Stokes
FRC #5817 (Uni-Rex)
steelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant future
Re: pic: My Rendition of Emperor Swerve
I knew that your math was correct 973 has used the design successfully (and quite fun to watch IMHO).
When you said "standard" FRC I thought that was the normal size, the larger size makes a lot more sense.
However, I still disagree that doing so can make things less complex it all comes down to your ability as a designer, what I find simple others can view as complex.
Good enough is the enemy of anything great!
team 1671
