Go to Post Inspiration is created by a vision and is reinforced with success. - rourke [more]
Unread 16-08-2012, 17:30
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: pic: 254 2010 Gearbox 1
Originally Posted by SilenNex View Post
You mentioned changing the bores on the AndyMark gears. We were talking about doing something similar, specifically boring a 3/8th bore out to a 1/2 and then broaching it. I was wondering if you could give a bit more information about what set up you used and how you went about it.
Unsure what 254 does, We have bored out our dog gears to accept a R10 bearing and to broach to a bigger size numerous times. We take softjaws on the lathe and bore them out to the gear diameter. We hold the gear and open the bore via a boring bar.
-RC
R.C.
MadTown Robotics Team 1323
pic: 254 2010 Gearbox 4 craigboez Extra Discussion 5 25-12-2010 19:38
pic: 254 2010 Gearbox 6 craigboez Extra Discussion 10 22-12-2010 22:13
254 Gearbox Analysis craigboez Technical Discussion 8 22-12-2010 09:17
pic: 254/968 Gearbox - Destructive Testing Results Travis Covington Technical Discussion 23 19-06-2007 14:58
254/968 Gearbox Assembly Time Study/Analysis Travis Covington Technical Discussion 8 08-05-2007 13:40
