Go to Post CNC machine, Something every FIRST kid wants in their bedroom :) - David Kelly [more]
Unread 17-08-2012, 02:29
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: pic: 254 2010 Gearbox 1
Originally Posted by DampRobot View Post
Just wondering, what are the prices and lead times like for Martin gears? We've been using SDP-SI, and I was wondering how they compared. Just looking at their catalog, their selection in some regards is certainly larger.
Generally we get them from Motion Industries. Prices are fairly reasonable (better than McMaster). I want to say they varied from about $30 for a 50T to $8 for a 12T. Most gears are in stock in Sacramento/LA. Some have to come from the factory in Texas.
McMaster can also get you any Martin gear that is not listed in their catalog. I don't know how the lead time/price compares to Motion.
SDP is probably the worst supplier we use. For a few years we've been referring to them as (Out of) Stock Drive Products. We've had some quality issues as well. Also very expensive.
Originally Posted by SilenNex View Post
Thanks for the quick replies. Since we don't have a CNC machine we will most likely be trying the lathe approach, can you recommend any good boring bars or associated tooling?
We don't do a lot of boring on the lathe, as we tend to put parts that would normally be turned on the CNC mill if they require much material removal/accuracy, but when we do, for small diameter boring we use whatever random brazed carbide bars are around.
I've never liked these as they tend to have large tip radii and are not very sharp. Something like this would be great, but kind of expensive. You could find similar HSS/carbide tipped tools elsewhere for cheap.
We have a 1" indexable boring bar that works great. Same as this. Inserts can be expensive (about $5 ea), but the ones we get are designed for aluminum (all we use it for) and are extremely sharp, which is beneficial on small lathes. You can also use the inserts for OD turning, with a different tool holder.
2001-2004: Team 100
2006-Present: Team 254
pic: 254 2010 Gearbox 4 craigboez Extra Discussion 5 25-12-2010 19:38
pic: 254 2010 Gearbox 6 craigboez Extra Discussion 10 22-12-2010 22:13
254 Gearbox Analysis craigboez Technical Discussion 8 22-12-2010 09:17
pic: 254/968 Gearbox - Destructive Testing Results Travis Covington Technical Discussion 23 19-06-2007 14:58
254/968 Gearbox Assembly Time Study/Analysis Travis Covington Technical Discussion 8 08-05-2007 13:40
