Go to Post "Look, it's already weight optimized!" - Samk [more]
Unread 21-08-2012, 19:48
steelerborn's Avatar
steelerborn steelerborn is offline
Engineer at JBT FoodTech
AKA: Jonathan Stokes
FRC #5817 (Uni-Rex)
steelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant future
Re: pic: Team 3647: Off Season Teaser 1
Nice, yeah configurations would be perfect for this scenario.
The Banebot Pinion gear is a 24dp I believe.
http://www.3dcontentcentral.com/part...&catalogid=171
Here is a link for my wcp gear library part. You can use it to drag and drop the part into an assembly and you will be prompted to select from a list of every gear wcp has. I would give it a try if you want I use it all the time when I am playing around with gearboxes. Also comments are welcome
Good enough is the enemy of anything great!
team 1671
