Go to Post You know you've been involved with robotics too long when you see a remote-controlled traffic barrel coming up behind people and honking - and it doens't faze you. - GaryVoshol [more]
Unread 22-08-2012, 22:35
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
Re: pic: Single Speed Gearbox Iterations
You can get that entire reduction in 1 stage. Lighter, simpler, more efficient.
12:72 will work with a 4" wheel, and actually gets more reduction than you have right now. (12:69 would be right about where you are currently.)
I always use a 12t or smaller on my CIMs because it allows us to put the gear on the CIM before installing it through the CIM 0.75" pilot hole.
Instead of spending money on COTS gears, you could go find a local shop who can make you some custom aluminum 72-toothers for cheap (or free). You're not going to need a whole lot of gear, should be nice and light.
-John
Unread 23-08-2012, 00:20
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
-John
Quick question from this; because we like to be able to put the gear on the CIM before we put it in the gearbox, I bored the CIM mounting holes to about .9 so a 14th would fit though it; so does it really matter that you use a .75 pilot hole?
Unread 23-08-2012, 00:25
IanW's Avatar
IanW IanW is offline
Rookie Mentor
AKA: Ian
FRC #0997 (Spartans)
The idea behind using a .75" pilot hole is to help align/center the CIM, which has a protrusion at the base of the output shaft that is also .75" in diameter.
Website
Facebook
Unread 23-08-2012, 00:26
Mk.32's Avatar
AKA: Mark
I understand this but is it really necessary?
Unread 23-08-2012, 00:34
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Mark,
I highly suggest it. The thing with the .75 hole is that it supports and locates the CIM. We've had older robots have the CIMs come loose and sometimes even break bolts because the bolts took all the load. John is spot on with the .75 hole.
We use the 14T gear still. We just slide the CIM in with the spacer and put the gear on and add the push nut/retaining clip. Its not that much time (30 seconds more).
-RC
R.C.
MadTown Robotics Team 1323
Unread 23-08-2012, 00:41
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
No, but your gearbox will perform much better (with less effort) if you do.
2001-2004: Team 100
2006-Present: Team 254
Unread 23-08-2012, 01:06
JVN JVN is offline
@JohnVNeun
As said by others... it is not a good idea to locate the motor using the motor mounting screws. That little .75 pilot hub is great because it helps ensure good center-center distance.
Aside:
I don't see any reason to use a 14t over a 12t. Whatever gear math people are doing which says 14 is better than 12... I haven't seen it, and I like to think I've played with these numbers quite a bit.
-John
Unread 23-08-2012, 01:10
Mk.32's Avatar
AKA: Mark
Cool, thanks for the tips.
definitely use the .75 CIM hole on my next boxes.
Unread 23-08-2012, 15:51
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
Here is our prototype from earlier in the summer:
Todd F.
Photo gallery
video channel
Triple Helix mobile
Unread 23-08-2012, 15:56
What I like;
-Combing the upper standoffs with the CIM bolts! So many advantages here.
-Overall profile looks clean and logical.
-Pocketing is a solid start, that's the hardest thing to do right... and everyone has a different opinion of what looks good.
-Combining the lower standoffs with your frame mounting.
-Using the same plate for both plates.
Unread 24-08-2012, 07:54
mwilbur's Avatar
mwilbur mwilbur is offline
AKA: Matt Wilbur
mwilbur is a glorious beacon of lightmwilbur is a glorious beacon of lightmwilbur is a glorious beacon of lightmwilbur is a glorious beacon of lightmwilbur is a glorious beacon of light
What I like;
You're spot on with our thinking, but note that the plates are mostly the same because the CIM-side plate uses a 7/8" OD (FR6) bearing on the output shaft rather than the 1.125" (FR8) bearing on the output plate side. Otherwise, there are no differences between the plates, although we had considered tapping the screw hole in the CIM-side plate to elimnate the nuts.
The "design" is really more or less a copy of what we've observed in the Cheesy Poofs' gearbox designs. We wanted to start simple with a single speed gearbox, then move forward at a comfortable pace to determine what works best for us.
Matt Wilbur
Head Coach, Triple Helix
FRC Team 2363
Menchville High School
Newport News, VA
Triple Helix... it's in our genes!!!
Unread 23-08-2012, 17:55
-John
The benefit could be a better running gear mesh. I believe a 12 tooth gear has an undercut at 20 pitch and 14.5 degree pressure angle, while I think a 14 tooth is out of the range requiring the undercut geometry. That said, for typical FRC applications, I'd still go with 12 tooth gears, since they fit through the hole, as others stated. And yes, I too highly recommend a close-fitting .75" hole to locate the motor.
Unread 23-08-2012, 18:46
Garret's Avatar
Garret Garret is offline
AKA: Garret Smalley
Would a better running mesh mean more a more efficient or quieter stage in the gearbox? And would there a mathematical method of calculating at what point there is an undercut?
7 Years of FRC
Unread 23-08-2012, 19:21
I'd have to confirm this, but an undercut shouldn't be any less efficient. It just needs the tooth to be reduced in size near the base to prevent impact of teeth; the involute surface should still be maintained.
It really is a substantial strength decrease; but as shown by numerous robots running them they are still strong enough.
Unread 23-08-2012, 19:25
Garret's Avatar
AKA: Garret Smalley
Thanks, I never realized the strength decrease but it makes a lot sense thinking about it now.
7 Years of FRC
