Re: pic: Single Speed Gearbox Iterations
As said by others... it is not a good idea to locate the motor using the motor mounting screws. That little .75 pilot hub is great because it helps ensure good center-center distance.
Aside: I don't see any reason to use a 14t over a 12t. Whatever gear math people are doing which says 14 is better than 12... I haven't seen it, and I like to think I've played with these numbers quite a bit. -John |
Cool, thanks for the tips.
definitely use the .75 CIM hole on my next boxes. |
Here is our prototype from earlier in the summer:
What I like;
-Combing the upper standoffs with the CIM bolts! So many advantages here. -Overall profile looks clean and logical. -Pocketing is a solid start, that's the hardest thing to do right... and everyone has a different opinion of what looks good. -Combining the lower standoffs with your frame mounting. -Using the same plate for both plates. |
You're spot on with our thinking, but note that the plates are mostly the same because the CIM-side plate uses a 7/8" OD (FR6) bearing on the output shaft rather than the 1.125" (FR8) bearing on the output plate side. Otherwise, there are no differences between the plates, although we had considered tapping the screw hole in the CIM-side plate to elimnate the nuts. The "design" is really more or less a copy of what we've observed in the Cheesy Poofs' gearbox designs. We wanted to start simple with a single speed gearbox, then move forward at a comfortable pace to determine what works best for us. |
The benefit could be a better running gear mesh. I believe a 12 tooth gear has an undercut at 20 pitch and 14.5 degree pressure angle, while I think a 14 tooth is out of the range requiring the undercut geometry. That said, for typical FRC applications, I'd still go with 12 tooth gears, since they fit through the hole, as others stated. And yes, I too highly recommend a close-fitting .75" hole to locate the motor.
It really is a substantial strength decrease; but as shown by numerous robots running them they are still strong enough. |
EDIT: Reread, you're referring to the undercut gears not the plastic gears. Your Point is valid. Last edited by AdamHeard : 23-08-2012 at 21:15. |
#12
Suggestion,
A couple of pressed in stainless steel guide pins would make this baby slide right in/out and align to the mating shaft and frame. Using guide pins can reduce the number of bolts to the frame and provide a accurate fit. See how a car transmission bolts to a engine. Usually a couple of pins on the bell housing that mate to blind holes on the engine. The pins help to align the shafts and just a couple of bolts to hold the transmission on. Roy Last edited by roystur44 : 23-08-2012 at 22:05. |
#13
z = 2 / sin^2(a) where a is the pressure angle. Interestingly, this isn't dependent on pitch. |
#14
Hey guys I really appreciate all of the discussion and its helping out a LOT. There is a bunch of things that I've seen, like the CIM .75 shaft guide extrusion, that have really helped me out with more detailed design.
On that note, wouldn't it be possible to have a press fit of x OD and .75 ID to fit over the CIM that would allow the possibility to help guide into larger sized holes? I feel as if the trade off would only help getting a much larger reduction in a smaller packaging and ultimately a smaller finished assembly. If anyone opposes to the fact or sees it as being not beneficial then please let me know! |
