Re: pic: Single Speed Gearbox Iterations
Cool, thanks for the tips.
definitely use the .75 CIM hole on my next boxes. |
Here is our prototype from earlier in the summer:
What I like;
-Combing the upper standoffs with the CIM bolts! So many advantages here. -Overall profile looks clean and logical. -Pocketing is a solid start, that's the hardest thing to do right... and everyone has a different opinion of what looks good. -Combining the lower standoffs with your frame mounting. -Using the same plate for both plates. |
You're spot on with our thinking, but note that the plates are mostly the same because the CIM-side plate uses a 7/8" OD (FR6) bearing on the output shaft rather than the 1.125" (FR8) bearing on the output plate side. Otherwise, there are no differences between the plates, although we had considered tapping the screw hole in the CIM-side plate to elimnate the nuts. The "design" is really more or less a copy of what we've observed in the Cheesy Poofs' gearbox designs. We wanted to start simple with a single speed gearbox, then move forward at a comfortable pace to determine what works best for us. |
