Re: pic: Single Speed Gearbox Iterations
It really is a substantial strength decrease; but as shown by numerous robots running them they are still strong enough. |
EDIT: Reread, you're referring to the undercut gears not the plastic gears. Your Point is valid. Last edited by AdamHeard : 23-08-2012 at 21:15. |
Suggestion,
A couple of pressed in stainless steel guide pins would make this baby slide right in/out and align to the mating shaft and frame. Using guide pins can reduce the number of bolts to the frame and provide a accurate fit. See how a car transmission bolts to a engine. Usually a couple of pins on the bell housing that mate to blind holes on the engine. The pins help to align the shafts and just a couple of bolts to hold the transmission on. Roy Last edited by roystur44 : 23-08-2012 at 22:05. |
