Go to Post FRC isn't all of FIRST. - Rich Kressly [more]
Unread 24-08-2012, 09:59
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: pic: Single Speed Gearbox Iterations
Originally Posted by Nate Laverdure View Post
Both the 12-tooth and the 14-tooth pinions will be undercut, but the 12-tooth more severely so. From page 141 (PDF link):
The formula for the number of teeth (z) required to eliminate undercut is:
z = 2 / sin^2(a)
where a is the pressure angle. Interestingly, this isn't dependent on pitch.
It is independent from the pitch since all gears of the same pressure angle and tooth count are geometrically similar. All 14.5 degree pressure angle gears with 24 teeth are the same profile, just at different scales.
Unread 24-08-2012, 18:34
rcmolloy's Avatar
rcmolloy rcmolloy is offline
AKA: Robert Cory Molloy
rcmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond repute
Hey guys I really appreciate all of the discussion and its helping out a LOT. There is a bunch of things that I've seen, like the CIM .75 shaft guide extrusion, that have really helped me out with more detailed design.
On that note, wouldn't it be possible to have a press fit of x OD and .75 ID to fit over the CIM that would allow the possibility to help guide into larger sized holes? I feel as if the trade off would only help getting a much larger reduction in a smaller packaging and ultimately a smaller finished assembly. If anyone opposes to the fact or sees it as being not beneficial then please let me know!
FRC 1647: Iron Devils - 2009 - 2011
FRC 973: Greybots - 2011 - 20XX
"While I was a student in FIRST, it was all about becoming inspired. Now as a mentor/engineering student, it's all about making sure learn everything I can so I can carry that on inspiration for future generations while having a hell of a lot of fun!"
Unread 24-08-2012, 18:41
This is totally possible, but if you want a larger reduction in a smaller package, that's exactly what a 12T pinion would do for you!
Unread 24-08-2012, 19:38
rcmolloy's Avatar
Ah ok! I suppose I just had my logic a bit backwards when writing the post. Also, proved it with a little bit of math too haha.
Unread 24-08-2012, 20:49
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
..., wouldn't it be possible to have a press fit of x OD and .75 ID to fit over the CIM that would allow the possibility to help guide into larger sized holes?
You probably have noticed plastic guides on FP motors in the FRC Kit of Parts. (shown here, for example) They are used in exactly the way you described. Of course as Chris just pointed out, the reason for using a pinion larger than the motor's metal pilot feature is not to enable a larger gear-down ratio. It is to enable a larger pinion pitch diameter. This will reduce the stress at that gear mesh, increasing the service life of the (plastic) gear which mates with the pinion.
Richard Wallace
since 2003
