Go to Post "The compressor is half the temperature of a toasted Subway sandwich." - Ashley Hartley [more]
Unread 24-08-2012, 20:08
James Kuszmaul James Kuszmaul is offline
NEFIRST CSA
FRC #0971 (Spartan Robotics)
James Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud of
Re: pic: 2012 frc971 transmission
I'm not seeing how this is single reduction. I can't get the numbers even close to those speeds, and in the picture it looks like the gearshaft is above the wheelshaft (or the wheels would hit the CIMs).
Is there another gear reduction external to this gearbox that directly drives the center wheel?
You are correct; A 15 tooth gear coming from he transmission drives a 50 tooth gear which is on the same axle as the wheel.
FRC971 (Student) 2011-2014
FRC190 (College Mentor-ish) 2014
WPILib Development 2014-present
