Go to Post For FIRST robots, the phenomena listed above just do not apply. - Paul Copioli [more]
Unread 27-08-2012, 01:57
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Re: pic: 2012 frc971 transmission
The use of the final gear allows us to make the transmission removable while the belts and wheels can stay on the chassis all tight. Let's see a WCD do that.
We need to make the inside side plates a little stiffer by insert some bends into the plate. This will give us a flange to mount the plastic grease guards.
We need to insert alignment pins from the transmission to the chassis to ease the assembly and get the optimum gear spacing. We had to manually tune the alignment and if the screws became loose the transmission would have power loss.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
