Go to Post The Tesla came in the blue tote. This is why you should always inventory your KOP before the replacement window closes! :p - sparrowkc [more]
Unread 27-08-2012, 17:15
Nate Laverdure's Avatar
FRC #2363
Re: pic: 2012 frc971 transmission
I love the space savings with this "inverted" setup, but in order to place the CIMs outboard of the gearbox, you risk a higher moment of inertia. This will have the effect of making the robot harder to turn.
Some quick calculations tells me that moving the CIMS outboard will increase the total moment of inertia by about 5% (for a "long" chassis) to 8% (for a "wide" chassis) for an otherwise equally-distributed robot. For a constant turning torque, this results in a similar percentage less angular acceleration.
Takeaway: for a snappy turning response, mount your heaviest items as close to the center of rotation as possible.
