Go to Post We don't tell new mentors about the Mentor VIP Adults Only Lounge, you'll get your key if we approve. We have leather couches, flat screens, and free corndogs in there. - Monochron [more]
Unread 29-08-2012, 20:37
scottandme's Avatar
scottandme scottandme is offline
AKA: Scott Meredith
FRC #5895 (Peddie School Robotics)
scottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond repute
Re: pic: 2012 frc971 transmission
You get a little more freedom if you aren't set on running the belts internal. That would let you pick a lighter profile tubing for your frame as well.
That's true, I think it'll be the pulley diameter needed that dictates that decision more than the weight gain/loss. 2x1x0.125 is 0.8085 lb/ft vs 1.036 lb/ft for 2x2x0.125, so it's only ~1.3 lbs lighter all said and done. Probably figure some weight added when you push the gearbox further inside the chassis to accommodate the ~1.25" of belt.
It's been hard to find enough detail from some CD research, but here are some I found.
1625 ran 2x1 frame with 9mm wide belt http://www.chiefdelphi.com/forums/sh...ad.php?t=86668
2791 looks like they used 2x1 with a single 9mm belt in 2011, but I think they mentioned ratcheting going full fwd to reverse. Also needs idlers to maintain proper wrap, I would rather avoid that. (http://www.chiefdelphi.com/forums/sh...ad.php?t=94701)
2791's 2012 chassis looks like 4x2 tubing with two 15mm belts. (http://www.chiefdelphi.com/forums/sh....php?t=101454). More weight, and requires >4" wheels, but solves the belt problem at least.
