Go to Post Remember, just because you saw it on ChiefDelphi, doesn't make it true. - Karthik [more]
Unread 08-09-2012, 19:14
akoscielski3's Avatar
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
Re: pic: First attempt at Sheet Metal Chasis
Originally Posted by MattC9 View Post
1.) Do you know how you will mount the gear boxes or transmissions?
2.) Do you plan on tensioning the chain? If so how?
3.) how do you plan to assemble the pieces? welds? rivets? screw?
4.) I like how you planned out the chain paths
5.) You might be able to make the side plates shorter to lose weight.
But looking good so far keep on working, this is how you truly get good at CAD!!
Exactly what I was thinking. I've done 10 ish Chassis' now and I keep improving each time.
You may want to change your lightening holes. You can make triangle instead, they make your chassis as strong as it could be. With rectangle cut outs you will have more bowing.
Definitely cut down on the bottom off the chassis. its just extra weight. I usually have the axles 1" from the bottom of the chassis. still strong, and lose that extra and useless material.
If you are gonna desgn something, make sure you have all your parts needed for it. You are gonna want to put transmissions in there. you will most likely not have enough material to mount them after. Transmission Supports/cross members are a good idea too.
Mka esure you design to your resources. Even If you don't want to build this you should practice building to your resources. Like do you have a sponsors or something to cut the material. And a way to bend it. You should ask yourself these questions while designing.
Good Luck! keep practicing!
Sorry if there is bad grammer. wrote this in a rush.
2013-Present
Team 772 Sabre Bytes
2010-2013
