Go to Post To the best engineers, scientists, and thinkers, something that is "hard" isn't something to avoid; it is something that begs for us to prove that we can do it. STEM is built on the very idea of trying something, failing, and trying something different. - Bryan Herbst [more]
Unread 09-09-2012, 01:49
tickspe15's Avatar
Purdue University
AKA: Spencer Tickman
Re: pic: First attempt at Sheet Metal Chasis
Originally Posted by Feroz1325 View Post
Looks good for a first time, however as others have mentioned you need space for a transmission in there, in our sheetmetal chassis we made mounting holes for the gearbox between the center wheel and the end and powered it via 35 roller chain.
Also be sure to leave sufficient ground clearance, many flat field frc games...aren't (bumps around towers in 2011, etc).
What thickness, material and bend radius are you using?
1/8 inch almuminum with a 2mm bend radius
