Go to Post FRC did a lot for me in high school. I couldn't pass up the opportunity to help it do the same for others. - Oblarg [more]
Unread 10-09-2012, 22:56
FRC #1678 (Citrus Circuits)
Re: pic: Team 3647: Gearbox
Originally Posted by MICHAELABICK View Post
Is there a reason you prefer the 1.125 OD bearing over this one: http://www.andymark.com/product-p/am-0439.htm ? I doubt they are going to be experiencing 40 lbs radial on that bearing.
Without knowing exactly how that shaft is loaded I wouldn't suggest using the 7/8 OD bearing. If they knew that the shaft was well bellow 40lbs load they could use the 7/8 OD bearing, but it's not difficult to design around a 1.125 OD bearing and bearings are not somewhere to cut corners on, I would never use that 7/8 OD hex bearing on a cantilevered output shaft.
