| Thread Tools |
Rating:
Display Modes |
[FTC]:Finding weighted rings vs regular rings
Okay so brainstorming a bit with some friends about this years FTC game Ring It Up! We came up with 2 easy ways of measuring the different rings and seeing that it is probably the most difficult aspect of this years teleop period I thought I would share and hear what everyone else has to say.
Option 1: Using a current sensor; If a motor needs to work harder to pick up a ring that must mean its heavier so if you measure the amperage the motor is drawing and having that read into a light that turns on or off depending on if the sensor trips. Option 2: Use a weaker actuator on an arm that cant pick up a weighted. This is a solution for both motors and pneumatic's. Yes I am biased towards opinion one that is why there is more text. I am anxious to here your ideas? |
Re: [FTC]:Finding weighted rings vs regular rings
Create a switch that will not trigger when something weighing less than 1 ounce... Then testing every ring, it would be most efficient to find a way to pick up the ring and then have your pick-up mechanism with a sensor on it. Basically eliminating the need to set the ring somewhere else on your robot.
This is my first season as a coach for FTC, I'm excited to see the competition! I'm also excited to make an awesome robot! |
However I would make it work for anything above 2 oz I know they light rings are .88 oz but to account for tolerance I'd say 2oz is safe. |
Some type of spring loaded trap door that rings slide/roll past and heavier rings drop through...
the lighter rings are hollow so you could use a light on whatever you use to pick up the rings on the heavy rings the light couldnt get through but the light would get through on the lighter rings
Rings are sold out on andymark... Assuming some FTC teams have already purchased them can someone post a picture when they receive them?
I just found this today while looking at sensors for FTC.
http://www.hitechnic.com/cgi-bin/com...on&key=NFS1074 From what I see, it's like an analog touch sensor, and it won't be available until October, but you could use it to differentiate the weight of the rings. |
Jason |
#10
As for sensing the wieght I have an idea for my design that would make it work. Since my robot (should) be able to pick up from both sides I would need two force sensors to figure out what the wieght one from each side. My claw would also need to pivot a smidge so that it could rest on the sensor given the orientation at any time. However instead of an automatic function I think a function for sensing should be on demand so that you can measure the wieght of said tube while the robot is -mostly- still so it gets an accurate measure without combining forces from moving around and getting ready to score. If the tube was weighted then an LED would light up somewhere on the robot to indicate that its a wieghted tube. From there you simply drive to the corner and score it. Those are my ideas how to go about finding wieghted tubes. - Andrew |
#11
Hold on to your shirts kids, here comes some physics: Force = mass * acceleration (whew!) The heavier rings will have a greater force of impact if allowed to fall the same distance as the lighter rings, and if they hit the same spot. Calculating the actual force of impact takes the rest of the kinematic equations (as well as some experimentation to figure out distance of deceleration & duration of impact. In any event, more force = more spring extension or more cantilevered polycarbonate sheet deformation. As for the rules -- I don't believe springs are allowed. However, surgical tubing and deformation of polycarbonate are allowed. |
#12
A really popular method in my team is a spring.
If your grabbing mechanism, say, a claw, is attached to a spring that's hooked up to a stationary point at the top of your bot, then: 1) When the claw grabs a regular ring, it will expand by X centimeters. 2) When it grabs a weighted ring, it will expand by 3X centimeters. You'll be able to see it very easily. |
#13
Consider the reality that only a limited number of successful trips between the dispenser and the scoring rack are possible in the 2+ minutes of driver control.
If a reasonable amount of rings are not scored, of what real value will the heavy rings be? Can you afford to wast one scoring cycle to place one or two 20% bonus heavy rings? We decided that only if two rings were adjacent on the dispenser pipe and could be taken together, would they be worth the time it takes to waste one cycle of scoring two rings at the rack. The odds for a pair of heavy rings being randomly placed adjacently on the dispenser bars is fairly low based on my rough estimation. So, how many scoring rings can be dropped to the floor in order to get a pair of heavies together in order to justify the trip to the corner? Our team concluded that unless we could first establish at least 30 pts. worth of row or column scoring bonus points, that going after heavy rings was a greater waste of our scoring possibility time, than what a heavy ring or two scored in the corner would yield. However, having a partner can also score rings quickly and one bot that can sort out the heavy ones and put them back onto the free space of one dispenser bar, so so one bot can then take pairs of heavies over to the corner, this could prove to be a powerful scoring strategy. -Dick Ledford Last edited by RRLedford : 11-10-2012 at 22:14. |
#14
I was under the impression that just the ring scores were multiplied by the corner rings, not line scores or any other ring bonuses. We are thinking that unless the other bot can quickly score lots of 30's, the corner bonus may not be worth it.
#15
To the contrary, let's say a team decides to forgo the top row completely in lieu of a simpler robot for a December competition. This is a stark reality for many FTC teams. The scoring analysis boils down to how many 'extra' points would going for the top row give if it were designed for instead of adding a weighted ring detector. The analysis would also have to break down how many weighted rings could be scored in the same amount of time it took to own the top row, let for now let's assume a 1:1 tradeoff.
On the surface, this seems like a no-brainer -- go for the top row. Yet there are underlying tradeoffs that may allow the low-peg team to pull ahead in most situations:
*Get creative! One doesn't NEED gravity to detect the weighted rings, as my students were quick to point out to me. Last edited by JesseK : 12-10-2012 at 10:51. |
